Old November 2nd, 2010, 15:49
Techno Duck Techno Duck is offline
Transfer case lever bushing replacement Q
Ive had the kit in my glovebox for over a year and a half now so i figure its a good time to replace it before the cold really kicks in . Also i can finally remove the sunglass case wedged inbetween the x-fer case handle and console to stop the noise... . This is on my '00 Sport.
Anyhow it appears the bracket mounted on the body needs to be removed to replace the bushings. Am i correct in that i need to remove the center console so the carpet can be pulled far enough back to access the bolts on the inside of the trans tunnel? Just want to make sure before i start taking things apart.. ive looked at this link and wish the carpet was so easy to pull up on the Cherokee..
http://www.4x4xplor.com/T-CaseTSB.html
Old November 2nd, 2010, 22:11
lawsoncl lawsoncl is offline
Re: Transfer case lever bushing replacement Q
The body side mount doesn't need to come off. Eveything is done from underneath. Just remove the two screws holding the little plate against the bracket.
Old November 13th, 2010, 17:51
praetorian praetorian is offline
You do this yet?
Transfer Case replacement 99 XJ copper_blue OEM Tech Discussion 4 March 10th, 2010 09:11
Transfer Case replacement feelinsomewheelin OEM Tech Discussion 2 August 31st, 2009 18:09
Transfer Case replacement dbswede OEM Tech Discussion 2 May 4th, 2006 11:24
Transfer case mount/bushing/cushion Rasputin OEM Tech Discussion 1 February 18th, 2005 07:57
Transfer Case Bushing seand OEM Tech Discussion 0 August 30th, 2004 09:13
