OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
1997 Fender Foam Inserts
Does anyone know where these fender foam liners go......I bought a damaged Jeep and I am took off the fender to replace it with another and out fell these pieces of foam. I can't tell where they come from and I don't see them in a parts diagram.....I want to put them on in their intended locations.
#2
Re: 1997 Fender Foam Inserts
#3
The smaller piece is glued to the bigger piece and if you look at the back of the fender in front of the door will see the shape of the foam letting you know where it goes.
I chose to use a 3" diameter pool noodle there instead. Cut in half diameter wise and to the appropriate length. Would show you some shot but one of the things I don't like about this site is that I can't post pictures like I can on the other forums without a third party photo thing. Which I refuse to do. LOL. |
#4
I'm not sure what this foam is for, but I am sure that I am not a fan of anything that holds water against steel parts because that usually is where rot problems occur. Unless it is needed for some very good reason, I would leave the foam out personally.
#5
Its closed foam so it doesnt hold any water, they are there to keep water, mud, and debris from being throw up and into the door hinge area!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
1997+ factory fender flares | 4wheel98cherokee | SoCal For Sale | 4 | February 17th, 2016 07:39 |
Stock Fender Flare Parts - 1997 Cherokee Country (FREE) | CARDIEYAK | Arizona For Sale/Wanted | 1 | May 23rd, 2014 21:02 |
WTB: Rear Fender Flare Brackets---1997 | FreemansXJ | MWC For Sale/Wanted Forum | 3 | August 17th, 2009 20:05 |
1997 Jeep Cherokee fender flare brackets | Bdiddy11 | OEM Tech Discussion | 7 | May 5th, 2009 07:32 |
Jeep Cherokee 1997 - 2001 Fender Flares | mdl | For Sale: Private Party Only. XJ ITEMS ONLY | 7 | December 19th, 2006 22:16 |
