Old February 20th, 2023, 09:15
90xj06's Avatar
90xj06 90xj06 is offline
Re: 2001 jeep intermittent misfire.
Originally Posted by RetEBoogie View Post
Also the tach is kinda jumpy when it misfire.
how jumpy? like sharp drop to 0 and pops back up? you might be losing the crank signal completely. check to make sure the wire isn't melted or shorting on the exhaust.
Old February 21st, 2023, 07:25
RetEBoogie RetEBoogie is offline
So I got off shift today and decided to check the ECU or PCM due to the randomness of the misfire. I've attached some photos of the only thing I found. There was some corrosion under the circuit board in one spot. Any idea if this would alter the functions of my ECU? Well now I can figure out how to post the photo lol.
Old February 23rd, 2023, 10:09
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
You'll need to upload the photo to a hosting site like imgur or flickr, then you can put a link to it here in the forum.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old May 6th, 2023, 07:23
Red face Re: 2001 jeep intermittent misfire.
So a little up date on the xj. I have replaced the ECU, crank, cam, ignition coil, the connector to the coil, inspected the engine harness, synced everything, and I still have a miss fire to the point I'm unable to drive the jeep at all. It is completely intermittent sometimes it runs fine but 90% of the time it runs like crap. I've scoured the site for any info and have done everything I have found to do or check. The code is intermittent loss of cam or crank and coil circuit A above or below threshold. I'm at a loss and need a little help before I junk this thing. Appreciate the help in advance.
Old May 6th, 2023, 09:24
RCP Phx RCP Phx is offline
Question Re: 2001 jeep intermittent misfire.
When my 2000 started having similar issues, it was the wiring cross-shorting between cylinders and eventually took out one of the drivers in the pcm.
Have done a megger test on the wires?
Old May 6th, 2023, 13:41
I'm unfamiliar with the test you speak of.
2001 Jeep cherokee misfire/runs rough!!! Lanser1999 OEM Tech Discussion 7 February 10th, 2019 12:38
P0304 Misfire, intermittent idle issues MrShaft696 OEM Tech Discussion 1 July 7th, 2013 18:19
1994 XJ intermittent misfire/poor idle on startup LawDawg007 OEM Tech Discussion 4 May 7th, 2012 09:01
intermittent cylinder 2 misfire Fowler.Alex OEM Tech Discussion 1 November 20th, 2011 08:22
Chronic, Intermittent, Cylinder misfire ! ! GHFCWheeler OEM Tech Discussion 17 May 31st, 2011 19:29
