OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#31
Re: Diagnose rattle under shift knob?
Given your description I would have chosen the National as well. Parts are all a roll of the dice anymore.
It does at least sound like the shop is trying to get this properly fixed, especially if they are showing you what they are finding, such as the difference in pilot bearings. Thank you for the update, and please let us know how it resolves.
Project "Scope Creep": 1996 4wd 4.0L, AX15 The "Varmint-Mobile": 1997 ZJ Laredo, 4wd, 4.0L, Slushbox |
#32
UPDATE-SOLVED: Ok, i think this issue has been solved (for now.) The new throwout bearing has been installed, as well as a NEW PILOT BEARING. I saw the old pilot bearing and it was not tight on the shaft, if was definitely shot. The shop actually put in a whole new clutch again as well, just to be sure. I just got it back today and test drove it, and it is FINALLY quiet, with clutch pedal IN or OUT. It shifts beautifully. The worry is that the shop said they replaced the PB the first time they did the clutch, but when they took it off, 2 of the bearings on it were smashed in. I saw the bearing, it def looked messed up. But it also looked old. So unclear if they actually replaced it the first time. The worry would be that something is messing it up. But at this point, I'm thinking it was the original and just old. Everything feels tip top, today at least.
As for the transfer case/4WD: I ordered the Azzy Replacement Linkage for my Heep as soon as I could and had the shop install it. I had to be there for that because the guy could not figure it out based on the instructions I gave him. But we got it in correctly, and yes, this thing is a GREAT mod. Shifts cleanly into all 4 positions. The problem was the old linkage, and it not having been put together properly. Now it's all gone, so happy. SO: At this point, I think both of these issues have been solved. We'll see how things go over the coming weeks of driving. I'll update if any issues arise from the National parts that are in it, or the Azzy link. My Jeep still has a bunch of other issues (it IS a jeep) but I'm moving off of these two problems, finally. Thanks to everyone for all the suggestions and advice. This forum is the best- And much thanks to the shop: they made good on their promise to get things right. Overall they dropped the tranny about 5 times. Installed 3 new clutches, test drove it over 50 miles (I check) and most recently it was in shop for 3 weeks while they waited for parts and worked on this. They did not charge me for anything except the Azzy install time. On to the next problem...Thanks y'all |
#33
Great to hear.
And that sounds like a shop that deserves your repeat business.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Please help diagnose rattle/clunk on startup (video) | yzmuddereffer | OEM Tech Discussion | 6 | September 21st, 2012 15:02 |
Shift Knob | noresttill | OEM Tech Discussion | 7 | February 3rd, 2010 11:37 |
Shift knob | Mdub | OEM Tech Discussion | 15 | April 2nd, 2009 20:35 |
shift knob needed | solditforajeep | Modified Tech Discussion | 1 | August 26th, 2006 11:21 |
shift knob | Wondo | Modified Tech Discussion | 3 | May 23rd, 2005 14:19 |
