WhiskyZero
- Pnw
Hey y'all.
I've been chasing the code p1494 Leak Detection Pump code on my 2001 xj for months now and I'm at my wits end trying to get this thing through emissions.
The LDP and most of the under hood evap components are new, including the purge canister and solenoid. I've checked all the vacuum lines and haven't found anything loose, leaking, or disconnected. I even sprayed some brake clean around the hoses to confirm and didn't get any idle up while the engine was running.
Most of what I find for troubleshooting this online says to check vacuum lines, and if that doesn't work, to replace the purge solenoid, both of which I've already done. I'm not quite sure where to go from here.
Any ideas?
Any ideas?
