XJBLACK
- covington, ga
my wife has a 2001 jeep cherokee 4.0 2wd it began idling rough. I ran codes im getting cylinder 6 misfire. It also started shaking but the shake is only when accelerating and then begins to shake like the tires are bad in the rear steering wheel does not shake at all. But the ierd thing is it begins shaking only when the transmission shifts into what ever gear it is in at 45 mph.
I searched and cant find the two things related unless I have completly missed something. And these started happening at the same time.
Tire check they are fine. No low oil pressure. No high temps or overheating. does not feel as if it is going to stall. No play in driveshaft.
Any ideas
Any ideas
