xjnuttier
- lancaster, pa
:thumbup:Hey guys, i am in the process tomorrow of installing another rear axle seal on my Dana 44. I installed the diff in July, and drove it the 1st day, checked for leaks, and the drivers side seal was leaking. I pulled the shaft installed a new Timken SET10 bearing and retainer, and a also the oil seal, TRV'd the outer edge, and made sure to tourque down properlly. This past Sunday, I was over at my buddies house to measure my tailshaft for my SYE, and to work on his 01 that flopped on its passenger side on our last trip.. So I crawl under my rig, pull my rear straps, and LOL I found that annoying vibration, my rear u joint was toast, quick sap all good, and measured up the tail shaft.. Just as I was gettin out from under her, I noticed that tell tale sign of diff fluid coming out of the brake adjustmnet hole, and all over the tire.. DAM 44, I went back to mydays of my old 79 fullsize, and I remebered a similar experience when I replaced it's wheel bearing. SO i did a search and foung out about the speedy sleeves. I decided to order one from my local NAPA, and by the way they are 43.00 plus tax now, here in PA. found the bearing and seal for Cheap at Autozone, in Lancaster, the bearing SET10 is only 22.99, and the seal is 11.99, and I work for a Jeep dealer, so I am running in to use the shop press. NOW here is really my question. I have done a lot of searching, but I am barely finding out any real good info on installing these on the rear axle. I am a good mechanic, but I really like to have some pointers from the guys who are really familiar with the install of the sleeve, and give me some tips so this is thelast time I have to replace the seal... Thanks in advance.. :thumbup:
