Old November 30th, 2021, 18:25
maxbraketorque maxbraketorque is offline
Re: Clunking Noise when Climbing Steep Hills in 4wd
Those look like better quality than IRO. I added them to my list of XJ parts.
Old December 3rd, 2021, 07:47
Lost_Wrench Lost_Wrench is offline
UPDATE: It was indeed the driver's side motor mount that was the cause of the clunking while climbing in 4lo. The bolt going through the rubber housing was completely torn free of any of the rubber. I tested afterwards on a steep climb near home and all is well. Thanks anak and everyone else for the helpful suggestions.
Old December 3rd, 2021, 12:22
Anak's Avatar
Anak Anak is offline
Stranger
Glad to hear you got it fixed.
Thank you for updating us with the resolution.
Old December 4th, 2021, 09:09
Woodswanderer Woodswanderer is offline
Energy suspension makes poly inserts for the stock mounts that work well without any major increase in NVH. Just makes the XJ feel more like a v8 pickup at idle
Steep Hill Climbing Issues .40CalPatriot OEM Tech Discussion 0 July 28th, 2009 09:59
Fast clunking while climbing hills slow? chrisgerman1983 OEM Tech Discussion 8 January 13th, 2009 20:49
knocking when climbing steep hills Shomsky462 Modified Tech Discussion 37 December 27th, 2005 13:30
While climbing hills...(not tech) JeepXJ93 Non-Tech / Off Topic 4 October 2nd, 2004 16:58
Washer Fluid and climbing up steep stuff. Drunk tank OEM Tech Discussion 2 July 22nd, 2004 15:34
