Old June 23rd, 2009, 11:34
ChevelleSSLS6's Avatar
ChevelleSSLS6 ChevelleSSLS6 is offline
tranny cooler/radiator quick disconnect woes
Putting in a new radiator today... maybe efan as well if I can find that relay kit I purchased a year ago...
What is supposed to be a quick disconnect line is taking, oh, a lot longer than the regular fitting for the tranny line/radiator..
I am not happy... anyone have any ideas how to get it disconnected without getting out the sawzall?
-Matt
Old June 23rd, 2009, 11:45
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Re: tranny cooler/radiator quick disconnect woes
Hallo. Take rubber hoses and clamps. The pressure is not high.
'92 XJ
Old June 23rd, 2009, 12:41
Original_MudButt's Avatar
Original_MudButt Original_MudButt is offline
http://www.expeditionportal.com/foru...t=28118&page=3
Old June 23rd, 2009, 14:29
96 XJ Sport 96 XJ Sport is offline
I was able to get mine off without the little tool. Does your line have the yellow plastic ears that look like you just squeeze and it should come off? Well, it didn't at first, but by pushing the line further onto the tranny cooler output and THEN squeezing the plastic ears, it came right off.
Old June 23rd, 2009, 14:45
orange orange is offline
X2--
"Push together--Release latch--Pull apart" also works on the electrical connectors a lot of times. Good habit.
O
Old June 23rd, 2009, 20:13
willam willam is offline
I struggled with mine for about forever....then I just cut them with my dremel and a cutoff wheel.
The quick disconnects are mis-named. They are niether quick nor do they disconnect. rubber transmission line and hose clamps work well. It's not pretty but gets the job done. Doulbe clamp them for added security, it's been holding up fine, no leaks at all.
Old June 23rd, 2009, 21:57
jeep ride's Avatar
jeep ride jeep ride is offline
^^what he said^^
Old June 24th, 2009, 11:02
bigalpha's Avatar
bigalpha bigalpha is offline
Oh the huge manatee
Cut it off and double clamp a new trans hose line on. That crimped section will start leaking; I can almost guarantee it. I've done it to both my XJ and MJ. Dremel will take about 2 minutes.
1992 XJ, 4.0, AW4, D30/D35
Old June 24th, 2009, 15:20
Muddy Beast Muddy Beast is offline
Mine was a pain even with the tool, but after struggling for a good ten minutes, I desided to try twisting while disconnecting with the tool and of course...it came right off.
I've learned to be patient with things like that or it causes a lot more headache.
~Scott
Old June 24th, 2009, 22:05
Originally Posted by Original_MudButt View Post
didnt work for me... I got pissed off and used some fuel line and clamps.
Also it has leaks... tstat housing (new hesco one, but its leaky at gasket surface) and lower (new) radiator hose... I'm thinking the last one is actually the water pump..
Old June 24th, 2009, 22:59
Did you put gasket sealer around the gasket on both sides prior to install?
~Scott
Old June 25th, 2009, 08:34
~Scott
no... not a fan of scraping that stuff... I almost always install gaskets 'dry'. I'll try the 'goop'.
Transmission Cooler Line Quick Disconnect Retrofit Qs Fryphax OEM Tech Discussion 15 July 22nd, 2008 01:53
help - radiator, tranny cooler line BSH OEM Tech Discussion 13 August 19th, 2006 07:46
New Radiator / New Tranny Cooler Leak Harvo Modified Tech Discussion 3 June 18th, 2006 10:37
Tranny cooler line disconnect Jump This OEM Tech Discussion 3 March 6th, 2005 23:19
disconnect tranny line from radiator, 00 xj??? xj2k OEM Tech Discussion 1 May 28th, 2004 11:04
