Old April 19th, 2003, 17:29
TN William TN William is offline
Starts, Idles, Sputters, Dies
As the title states. This is on an 89 with 4.0. It was running great until I pulled it in my shop to replace an axle seal. While I was at it I installed a cone filter (homemade tube, attached 2 1/2" hoses, blocked off vac line) and changed the gasket for my fuel pump. Now it starts right up but begins to sputter and die within 10-15 seconds or immediately if I give it throttle. I checked all the vacuum lines.
Old April 19th, 2003, 17:31
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
did you chek the fuel pressure? You said you replaced the fuel pump gasket....
Kejtar
Old April 19th, 2003, 19:50
Sparks Sparks is offline
how about fuel pump relay or resistor. Sounds like resistor wire is unplugged
Old April 21st, 2003, 07:28
satan's Avatar
satan satan is offline
I'm with checking the ballast resistor as well (especially in an '89 - if it's early production the ballast may be close-enough to your home-made cone to have been involved with some kenetic event)
The best rocker protection debate starts now ericz Modified Tech Discussion 57 December 13th, 2003 14:45
Russian dies after winning vodka-drinking contest Hunter-Lynchburg,Va Non-Tech / Off Topic 2 November 19th, 2003 21:55
Idles like crap in gear and smooth in park and Neutral Tim88XJ OEM Tech Discussion 7 May 19th, 2003 09:51
Rough Starts and Bad Smells alphaXJ OEM Tech Discussion 1 May 2nd, 2003 15:21
XJ starts and then dies. BrokenXJ OEM Tech Discussion 10 April 29th, 2003 07:22
