Old November 30th, 2019, 15:27
blu3fan's Avatar
blu3fan blu3fan is offline
Re: changed oil. car dies now.
so.
new optima and cleaned the 3 grounds by the dipstick.
she runs.
Shes still giving this random stall/misfire 1 second every 60 seconds. gonna put a few miles on her and see if the stutter goes away.
she seems down on power.
ALL CEL'S ARE GONE !
Old November 30th, 2019, 15:33
blu3fan's Avatar
if the stutter doesn't go away I think new spark plugs might be in order.
But the main issue appears fixed.
Old December 1st, 2019, 17:23
blu3fan's Avatar
putting around the complex. she runs. does not stall.
Any throttle over 30-40% and she sputters and stumbles.
Since The only change has been cleaning the grounds on the distributor side I am hoping replacing the distributor then the coil is next on the agenda.
distributor doesn't arrive til monday.
meh....
Old December 1st, 2019, 19:18
Anak's Avatar
Anak Anak is offline
Stranger
That is at least progress.
I am going to suggest you consider going beyond just cleaning those connections.
See this thread: https://www.naxja.org/forum/showthread.php?t=1148570
Examine your wires carefully. If they are like mine were they may be hard and brittle. That is a symptom which tells me those wires are not up to their job anymore. Higher resistance changes how sensors and the computer are able to do their job.
Baby it's cold outside.
Old December 1st, 2019, 21:45
blu3fan's Avatar
Anak my grounds looked like yours.. I was a tad worried about this too... good writeup. thats probly next for me.
I took a dremmel wire wheel to the 3 dipstick grounds all are shiny and di-electric greased now.
since I have already purchased the distributor. I am gonna throw it in.
The more that I think about this also.
I replaced the coil with a cheap one.
I just bought an MSD coil just for peace of mind.
Old December 2nd, 2019, 12:01
blu3fan's Avatar
After a ton more research. Narrowed down to.
Bad cps. Replaced once. Still can't rule it out.
Bad distributor. New one arrives today.
Bad coil. New one arrives Friday
Bad ground. Cleaned up the grounds but may need additional work
This could also be a pcm/ecu failure or harness failure
Old December 2nd, 2019, 12:36
Skwerly Skwerly is offline
I was thinking CPS or dizzy, myself.
Old December 2nd, 2019, 15:00
Dragonslayer Dragonslayer is offline
... "Any throttle over 30-40% and she sputters and stumbles."
When was the last time that you changed the fuel filter?
Just wondering.
Old December 2nd, 2019, 18:27
blu3fan's Avatar
its not fuel related.
Old December 2nd, 2019, 18:28
blu3fan's Avatar
New distributor tests good.
Since it came with the car side of the wiring harness gonna solder it in tomorrow.
Updates to come.
Old December 2nd, 2019, 18:42
blu3fan's Avatar
Anak. I went to my go to for wiring and spent like $10 for enough stuff to solder in a new ground. Knukonceptz is always my go to.
I am pretty much gonna copy your guide
cept I am gonna run a ground from the block side to the negative on the battery. call it overkill. but I am taking no chances at this point.
If replacing the coil fixes this I am gonna be so confused.
but I am replacing the $7 ebay coil with an msd blaster one.
Old December 2nd, 2019, 20:29
Anak's Avatar
Stranger
Extra grounds certainly won't hurt.
I don't recall exactly what the difference was, but I do recall that I had some notable improvement when I ran a new, larger ground between the battery and the top of the radiator support. It may have been that my headlights ceased acting like they were wired by Lucas. It was something of that scale. I have since added in relays for my headlights, really putting an end to that nonsense.
Having a good source for quality wiring components is important. I have been using Waytek for a couple of decades. They don't scale down particularly well for most folks' needs, but I don't mind having enough on hand to not have to worry about it the next time. It doesn't seem like copper ever gets cheap.
Old December 4th, 2019, 17:32
blu3fan's Avatar
so.
The msd coil is installed.
Maybe 5% better running sounding.
no huge change.
Distributor is a different design on the inside compared to mine.
Mine is like this one
https://www.google.com/imgres?imgurl... ct=mrc&uact=8
And the one I bought is like this.
https://www.google.com/url?sa=i&sour...75592117857422
Can I use this in the 92 ?
Old December 4th, 2019, 18:17
blu3fan's Avatar
2nd picture of the distributor I have. - https://ww2.justanswer.com/uploads/C...cam_sensor.gif
Old December 4th, 2019, 19:13
Anak's Avatar
Stranger
The link for the one you bought isn't taking me anywhere useful. Hard to compare without half the comparison.
That said, if the plug is the same the odds are the two are interchangeable (assuming both have the same external properties/mounting provisions). Folks have been playing around with distributor innards for decades. There are a number of different ways to trigger a coil (or computer).
Could I have my name changed Qban User Support, Questions and Suggestions 5 May 23rd, 2013 21:21
'95 XJ runs for a minute-dies, runs 2 minutes-dies, on & on...... Four2score OEM Tech Discussion 0 June 15th, 2011 09:06
What changed? Tommy4949 OEM Tech Discussion 3 May 19th, 2008 02:17
okay, so i just changed my CPS..... slammed73sb OEM Tech Discussion 1 December 11th, 2007 14:51
XJ dies, unplug something, starts, but dies 5 minutes later KingOfTheHill OEM Tech Discussion 6 April 26th, 2005 13:00
