Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Liberty KJ and KK (2002 - 2012)
Jeep Liberty KJ and KK (2002 - 2012) Technical forum for all Jeep Liberty (also known as Cherokee in non-US markets) vehicles.
Old January 26th, 2018, 09:32
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Bent valves and wiped cam?
Originally Posted by Ecomike View Post
If he buys a rig from the same folks, he will stick them with the problem and push for an extra break on the deal/cost.
If he can I guess that fine. Iíd hat for your son to lose money because heís stuck with a lemon. Is it a local warranty through the place he bought it? Kind of odd, but I could see a smaller local dealer try to make the profit on a selling warranties. If itís a local deal make them see their repairs made it undrivable. If itís national company keep on them until they replace the engine. Even after it expires as long as you reported the issues they still have to fix it.
Seems like new jeeps engines management systems are so complex once the have gremlins you keep fighting. Same thing for these aluminum head overhead cam engines. Once they overheat or drop a valve unless the repairs are done right it comes back to haunt. Iíve seen so many post from people who pick up a cheap KJ donít realize these engines are still very expensive and trying to piecemeal a repair will not work.
Iíd be curious to see service history for that KK, my guess is the dealer bought it with a engine problem and tried to patch it. Aside from a factory lemon there is no reason any low milage engine should fail like this.
BTW as your son is shopping around keep in mind any Chrysler product from the late 90s to 2012 with a 4.7 or 3.7 are the same engine as his KK has now. And oil changes are the lifeís blood of these newer engines.
Old January 30th, 2018, 20:21
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Bent valves and wiped cam?
It just threw a P0128 code, interesting, but not yet, by itself a clear bit of info.
" P0128 JEEP
Description
Indicates that the thermostat monitor has not achieved the required engine operating temperature within a specified amount of time after starting the engine.
Symptoms- CEL
Possible causes
- Insufficient warm up time
- Low engine coolant level
- Leaking or stuck open thermostat
- Faulty MAP sensor
- Engine coolant temperature sensor harness is open or shorted
- Engine coolant temperature sensor circuit poor electrical connection
- Faulty engine coolant temperature sensor When is the code detected?
Coolant temperature does not reach predicted engine coolant temperature within specific time
Tech notes
If cooling system is not leaking and the fluid level is OK, replacing the thermostat usually takes care of the problem."
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 30th, 2018, 20:40
Damn thatís weird.
One thing about the 3.7 mopar on the thermostat, I donít think thereís a good after market brand yet. Or the shop didnít connect the temp sensor or broke it. Itís in the middle of the engine under the alternator, or in about the area.
Ecomike's Avatar
NAXJA# 2091
From the prior post data on the PO128 code:
"Coolant temperature does not reach predicted engine coolant temperature within specific time
Tech notes
Thinking about the junk, metal shavings from the wiped CAM after those yahoos dorked up the head gasket job, maybe got into the T-state and it stuck open??? And I bet they did not even replace the T-stat, or they used cheap chinese one.
So far the coolant level looks OK.
Old January 30th, 2018, 20:43
Nah, the coolant I doubt would get the metal shaving, oil pump and bearings thatís another story.
Is it at least running correctly otherwise?
Bent valves and a wiped CAM on a 2010 Liberty? Ecomike Colorado Chapter 0 January 13th, 2018 12:30
Ford 8.8 bent shaft or bent axle RNMedic Modified Tech Discussion 10 July 1st, 2008 17:06
HELP!!! A/C Valves on a '93 XJ, NEED HELP!!! selarep OEM Tech Discussion 11 July 23rd, 2006 08:57
More of my 'family' wiped out,sheesh... RichP Non-Tech / Off Topic 1 September 23rd, 2004 14:03
what about these valves? Stoney Sierra Chapter 3 January 31st, 2003 15:23
