Old September 7th, 2008, 19:38
billyjp2's Avatar
billyjp2 billyjp2 is offline
Mid-241or swap
im swapping a rock trac in place of a 231 in my 94 xj. i believe the speedos are both 3 wire. is it possible to simply splice the wires or do i need the expensive adapter that someone makes. If splicing these is not possible could someone tell me what company makes the adapter. i searched but i couldnt find the name of the company.
Old September 12th, 2008, 18:44
Turfzilla's Avatar
Turfzilla Turfzilla is offline
Re: Mid-241or swap
GET a hold of a tera 4 lo instructions. I remember it had a wiring diragram that will help you. Post #19 http://www2.pirate4x4.com/forum/showthread.php?t=566955
Replace 231 TC with 241OR TC. Hickorynut Modified Tech Discussion 12 April 22nd, 2008 21:28
D300 flipped or 241OR Rubi t-case? bigblackjeep95 Modified Tech Discussion 11 January 16th, 2006 10:06
241or t-case moneypitxj Modified Tech Discussion 1 September 8th, 2004 15:06
241OR T-Case Skid? Thor Modified Tech Discussion 3 July 23rd, 2004 12:48
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
