xjj33p3r
NAXJA Member #1108
- garland, tx
I'm thinking that my steering box is plugged with something, mainly a small piece of plastic. The way I discovered this is after my jeep won't turn at all with weight on the tires. With the tires jacked up in the air, they will turn, but fluid comes out of the pump cap because of the pressure build up. It's not overfilled, so that's not the deal.
At first I thought it was the pump that had gone bad, as I didn't see any fluid flowing when the jeep was on. So, as I was taking it apart, and unbolting the hi-pressure lines, I noticed that a small piece of plastic had gotten stuck in the right most hole of the box. I pulled (what I thought was all) of the plastic out, and it still will not turn when the jeep is on even with my new pump. The box WILL turn when the pitman arm is taken off, and when the jeep is also off.
So, does this make sense to say that there is possibly still a piece of plastic plugging up the steering box somewhere? If anyone has some ideas, fill me in.
