Old July 25th, 2008, 23:34
Tracy92 Tracy92 is offline
D44 Ring gear bolts
I'm instaling a aussie locker in my D44 rear axle, and ran into a snag with torking the ring gear blots.
I have serched on line and for some reason, I'm reading some guys tork em at 80-90 ft lbs, and at the same time, someone els doing the same install on the same rearend will tell ya it's 55-60 lbs?
I was wondering if someone could tell me what the proper tork spec should be for ring gear bolts on a D44?
The jeep is a 87 xj 3.54 gears
Old July 26th, 2008, 01:18
5-90's Avatar
5-90 5-90 is offline
Re: D44 Ring gear bolts
All specs listed are from FSMs.
http://www.geocities.com/JeepI6Power/torque.html
Old July 26th, 2008, 07:14
Begster's Avatar
Begster Begster is offline
I just looked in my Yukon install guide, and it says 55 ft/lbs for the R.G. bolts, and 60 ft/lbs for the caps.
Ring gear bolts RangerRick Modified Tech Discussion 7 May 28th, 2008 18:35
Ring gear bolts for D44 with thick gear set? stoneattic Modified Tech Discussion 1 February 13th, 2008 10:37
Bolts backing out of ring gear??? ryurabbit Modified Tech Discussion 15 January 20th, 2005 18:24
8.25 ring gear bolts not fitting! Israel Modified Tech Discussion 4 November 2nd, 2004 20:49
Re-use ring gear bolts? Root Moose Modified Tech Discussion 4 October 26th, 2004 14:41
