Old June 18th, 2008, 16:15
new5000 new5000 is offline
Charging System Trouble
OK I have an 87 4cyl. I recently replaced a dead battery and then discovered that the alternator was only charging at 12V so I had it checked at autozone and it was only generating 5A. So I replaced the alternator. With the new alt. the charging voltage is still only 12V not the norm 13-15V. Sooo...new alt. and batt. and I checked all of the connections and wires and all looks legit. By the way all of the accessories work fine.
What am I missing here? Is there more to the charging system???
Why only 12V when I definately had 14V before, when all was good?
Old June 18th, 2008, 16:47
Re: Charging System Trouble
thanks for all the help guys
Old June 18th, 2008, 17:33
Saudade's Avatar
Saudade Saudade is offline
Wow, you waited a whole 16 minutes before getting pissed off no one replied?
Old June 18th, 2008, 23:24
Flyfisher's Avatar
Flyfisher Flyfisher is offline
I'd check, and re-check grounds. Jeeps are notious for bad grounds. Can cause all sorts of problems. Replace if in doubt.
Old June 18th, 2008, 23:42
5-90's Avatar
5-90 5-90 is offline
Especially RENIX-era (1987-1990, gas engine) XJ and MJ.
Pay particular attention to the ground strap from the cylinder head to the firewall - a shonky connection there can cause all sorts of headaches for you.
And, give your question some time before it gets answered. It helps...
Old June 19th, 2008, 01:15
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Hallo. It is better to take the measurements on the altenator itself. Did you?
Charging system gremlin Ernrok OEM Tech Discussion 4 January 1st, 2008 09:15
Questions about charging A/C system JoshRountree OEM Tech Discussion 12 October 26th, 2007 15:45
Charging system The Federation OEM Tech Discussion 4 October 25th, 2006 16:54
charging system rebelrat OEM Tech Discussion 2 July 10th, 2006 21:14
XJ charging trouble/fusable link? Chark Modified Tech Discussion 1 August 6th, 2005 09:11
