Old May 19th, 2008, 18:57
kumes12688 kumes12688 is offline
Dana 44 in a 1999
Hello,
I have to replace the rearend in my jeep. Right now it has a Dana 35 in it. My friend has a Dana 44 from a 1994 xj that he is willing to sell me, but I am wondering if it will fit in my 99 without modifications, and if there is modifications required what will they be. I am pretty sure it will fit but I just want to make sure.
Thanks
Old May 19th, 2008, 19:01
CanMan's Avatar
CanMan CanMan is offline
Re: Dana 44 in a 1999
Do you have ABS? If so, you gotta get around that first.
Also, did he swap in the 44?
If you do not have ABS, it'll swap right in.
Old May 19th, 2008, 19:02
Begster's Avatar
Begster Begster is offline
I have a D44 in my '99. You will have to use your ebrake cables though, not the ones that came on the d44 as they changed them at some point.
D44's did not come stock in '94 XJ's, only in '87-'89. Make sure it is a D44 before you buy it, and see if he installed it.
Old May 19th, 2008, 19:06
i do have abs so what would i have to do
Old May 19th, 2008, 19:08
CanMan's Avatar
Get rid of the system. Search, Im not sure what you can do on late models.
Old May 19th, 2008, 19:14
RCman's Avatar
RCman RCman is offline
Life is big block
... Dana 44 from a 1994 xj that he is willing to sell me ....
Not that came stock...
Make sure it really is a D44 that he's selling you. Unless he or someone else put it there, its not on. A D44 rear axle for that year is not original.
You'll have to get rid of it.
Edit: CanMan beat me to it
Old May 20th, 2008, 11:19
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
You can not have ABS and a D44 unless you are really good at fabrication. Just disable the ABS by pulling the ABS fuses and relays. The ABS junk can stay where it is at - it will do nothing and harm nothing.
I put a Chry8.25 in my 2000 to replace a D35 w/ABS. No problems.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old May 20th, 2008, 15:06
HMGanja's Avatar
HMGanja HMGanja is offline
So all I have to do to get rid of my Anti-lockBrakeShitstorm is pull the fuses/relay? And nothing negative will happen? btw I too have the '99...
Old May 20th, 2008, 15:20
gregmondro's Avatar
gregmondro gregmondro is offline
It'll be fine. Many have done this swap. I'm another user with a 99 who swapped in a XJ D44
Old May 20th, 2008, 15:27
HMGanja's Avatar
Thanks
Old May 20th, 2008, 15:55
NickThePyro NickThePyro is offline
Nice to read this since I have a 99 and a Dana 44 in my garage that im getting installed in a week
Old May 20th, 2008, 16:05
what about the gear ratios? I heard that the tranny will burn out if you have 3.55 in the front and 4.10 in the rear like i would if i put the d44 in. Is this true?
Old May 20th, 2008, 16:15
if your gonna put in a new axle you should regear both ends while your at it. That is only true if you have 4WD engaged. But whats the point of not regearing?
Old May 20th, 2008, 16:57
Timmy2XJS's Avatar
Timmy2XJS Timmy2XJS is offline
im sportin a 99 with a 44 out back and it was a a straight hook up. and yes regear it at both ends iv got 4.10s and they make me happy.
Old May 20th, 2008, 18:04
vetteboy's Avatar
vetteboy vetteboy is offline
The D44s never came stock in XJs with 4.10s, either.
Language filters are dumb.
Originally Posted by MoparManiac
I spent plenty of time farting
F/S 1999 4.0 1999mj NAC Classifieds 10 August 25th, 2007 12:45
1999 AW4 tikitgvr2 For Sale: Private Party Only. XJ ITEMS ONLY 4 January 14th, 2007 20:15
1999 XJ LTD with OME ARB RE and much more woodkrawler For Sale: Private Party Only. XJ ITEMS ONLY 4 January 21st, 2005 21:38
Need a 1999 4.0 OEM AIR BOX chipsahui2 Wanted: Private Party Only 0 December 30th, 2003 12:53
