Old January 26th, 2008, 07:39
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
Hose clamp
I need the lower radiator hose clamp on the engine side.
I tried to get it from the dealer but he wanted to sell me a worm screw type.
I want the original, the type that you squeeze the the two ends to install it.
Any help locating it will be appreciated.
I don't want to go to the junk yard if I can help it.
Old January 26th, 2008, 07:44
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
Re: Hose clamp
Advance auto has them so does NAPA
Old January 26th, 2008, 09:04
cjcargo's Avatar
cjcargo cjcargo is offline
Re: Hose clamp
What's wrong with just using a stainless steel hose clamp that is large enough? I like the ones that can be tightened using a socket myself.
Old January 26th, 2008, 09:15
icewolf73's Avatar
icewolf73 icewolf73 is offline
Re: Hose clamp
I prefer the screw down hose clamp myself. Easier to work with and seals better.
Old January 26th, 2008, 09:43
falcon556's Avatar
Re: Hose clamp
I like the spring type, besides, it keeps the Jeep original.
Old January 26th, 2008, 09:47
falcon556's Avatar
Re: Hose clamp
Just called both of them, they don't have the spring clamp, just the worm screw type.
Old January 26th, 2008, 09:51
falcon556's Avatar
Re: Hose clamp
I like them better. They constantly apply tension and never leak.
Worm screw type have failed me. After the rubber compressed a year or two after installation, they leaked.
Old January 26th, 2008, 11:00
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Re: Hose clamp
That's probably because no one uses them any more (even if anyone still makes them) because they are a pain in the... well...you get the idea.
The stainless worm gear type are more reliable (a wider band instead of a sigle piece of spring steel), they don't corrode and I can't imagine that anyone's ride is that "original". The factory put them in because they were cheap, fast and easy to put ON (not to take off). They make the little ones for non-pressure tiny hoses but I think you'll be hard pressed to find them for a radiator hose.
To each his own though, keep searching.
Old January 26th, 2008, 12:41
falcon556's Avatar
Re: Hose clamp
I have the locking pliers for these clamps and they work well for me.
Drive shaft clamp falcon556 OEM Tech Discussion 2 January 7th, 2006 20:10
Down pipe, clamp to tranny or no? Spanky414 OEM Tech Discussion 2 May 21st, 2005 09:42
steering box clamp Redcbr007 Modified Tech Discussion 7 September 6th, 2004 00:58
Getting clamp off tb hose? ZachMan OEM Tech Discussion 3 February 15th, 2004 20:03
Muffler install - how do I clamp everything in? jeep.xj.4x4 OEM Tech Discussion 15 October 1st, 2003 19:06
