Old April 29th, 2007, 18:29
xj joey's Avatar
xj joey xj joey is offline
full traction dented my shock
i have a full traction long arm lift and the big damn bump stop hit the rear shock. ever seen this happen? now my jeep rides like crap cause the shock can only compress 2 inches.
Old April 29th, 2007, 18:41
xj joey's Avatar
Re: full traction dented my shock
[IMG]file:///C:/DOCUME%7E1/JOE%7E1.DAN/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]here are some pictures
http://s89.photobucket.com/albums/k2...nt=jeep004.jpg
[IMG]file:///C:/DOCUME%7E1/JOE%7E1.DAN/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/JOE%7E1.DAN/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
http://s89.photobucket.com/albums/k2...nt=jeep003.jpg
Old April 29th, 2007, 18:48
CanMan's Avatar
CanMan CanMan is offline
I dont see how it was FT that caused the shock to be dented. Making sure everything is clearenced before wheeling or driving ones rig is something that needs to be done first. Id give FT a call, see what they say, and go from there. Looks like you need 1 shock, and then clearence the bumpstop mount.
Old April 29th, 2007, 19:09
JNickel101's Avatar
JNickel101 JNickel101 is offline
that's a crazy bumpstop plate....you should get the ones from DPG Offroad....
Old April 29th, 2007, 23:29
xj92's Avatar
xj92 xj92 is offline
Are they monotube shocks? How dented are they? If they're twin tube shocks they'll still work with a slightly dented exterior. Either way, do as recommended above and fix the problem before it gets worse in the future.
Old April 30th, 2007, 05:12
xj joey's Avatar
the dent is about the size of a quarther and 1/4 inch deep. its a low priced skyjacker shock. the piston stops at the dent and dont allow the shock to compress. it kinda sucks that i dented the shock but the jeep flexes like crazy!!!!
Old April 30th, 2007, 07:53
MrShaft696's Avatar
MrShaft696 MrShaft696 is offline
Old April 30th, 2007, 07:58
Ben H's Avatar
Ben H Ben H is offline
Cut that corner off the bumpstop plate, buy a new shock and be done with it.
Old April 30th, 2007, 15:28
xj joey's Avatar
i did more then dent it. just took it off. spoke to full traction today and they said i might have a shock thats to big but when i got it off and measured it was the same size as the ones they sell with the kit. [IMG]http://s89.photobucket.com/albums/k217/jmr1409/?action=view&current=jeep010.jpg[IMG]
[IMG]http://s89.photobucket.com/albums/k217/jmr1409/?action=view&current=jeep008.jpg[IMG]
Old April 30th, 2007, 15:30
xj joey's Avatar
couple pics
http://s89.photobucket.com/albums/k2...nt=jeep010.jpg
http://s89.photobucket.com/albums/k2...nt=jeep008.jpg
Old April 30th, 2007, 17:47
53guy's Avatar
53guy 53guy is offline
happened to me as well.... just grind off the corner. Did you install any axle shims in there when you put it on?
Old April 30th, 2007, 18:46
Green98xj's Avatar
Green98xj Green98xj is offline
i cut the corner on mine as well but i did it when i was checking all my clearences!!
Old May 1st, 2007, 11:18
spaghettixj spaghettixj is offline
I also cut the corner on mine before wheeling... ( I use 4 degrees axle shims).
Old May 1st, 2007, 13:45
RyanM's Avatar
RyanM RyanM is offline
yep thats your fault, get a new shock as those are like 30 bucks and get the angle grinder out
Old May 1st, 2007, 13:49
53guy's Avatar
If you used shims, that's why they hit your shocks. They (full traction) wouldn't have used shims and wouldn't have run into axle tilt issues that you would when you install shims.
Full Traction 6in xj joey Modified Tech Discussion 11 December 29th, 2006 09:21
full traction 3.5 fitchjr Modified Tech Discussion 1 December 6th, 2006 19:35
Full Traction??? XJmania030 Modified Tech Discussion 8 November 16th, 2006 10:18
Ok, someone has got to have the Full Traction kit by now? ZachMan Modified Tech Discussion 17 July 29th, 2005 10:15
full traction 3.5 kit cblevy98 Modified Tech Discussion 3 April 7th, 2005 15:45
