Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old September 29th, 2005, 22:13
corbinafly's Avatar
corbinafly corbinafly is offline
"Mmmm. More please."
AEM wideband O2 sensor/gauge readings
Well, I finally had my first day of driving with the new wideband O2 sensor/gauge setup. No more crazy light show like you get with the autometer gauge.
Looks like I'm floating right around 14.6:1 AFR during idle and cruise. But at WOT, I start out at about 13.2:1 AFR at around 3000 rpm then it richens up to about 11:1 AFR at 5000 rpm. Looks like I need more airflow at the higher rpms? What do you guys think? I thought I was running lean at WOT with the injectors that I have but I guess not.
Here's my setup:
95 XJ, AW4
Hesco 4.6 stroker, 4.0 rods, forged pistons, 9.42:1 comp ratio
WJ intake manifold
Borla header, hiflow cat, and magnaflow muffler with all 2.5" pipes
stock 39 psi fuel pressure
Accel 21# injectors (flows about 20#/hr at 39psi)
Airaid cone type filter
stock throttle body
msd ignition, screamin demon coil
So you think I need to work on the intake system?
Any input would be appreciated.
K
By the way, I posted this on the yahoo stroker group too. Just want as much input as possible.
Old September 29th, 2005, 22:34
Dingo509's Avatar
Dingo509 Dingo509 is offline
Re: AEM wideband O2 sensor/gauge readings
I thought 95 was higher fuel pressure than that? Anyway i would go with a bored throttle body and a newe" (99) irakd. t`t voul help apflnw a `t at h ah RPM's.
BTW how much did that Meter run you?
Dingo
Old September 29th, 2005, 22:57
5-90's Avatar
5-90 5-90 is offline
$349 at Marren Fuel Injection (www.injector.com)
Unless, of course, you can get a deal on a couple more? No hurry - but I'd like to have two or so for tuning (and a semi-permanent mounting for experimentation...)
I wouldn't even bother using anything that responded to a "knuckle" sensor - just not any useful information there. WBHEGO is the way to go - or just quit with measuring AFR that way and use a pyrometer...
5-90
Old September 30th, 2005, 05:49
rsalemi rsalemi is offline
Doesn't the 95 HO have a 5200 RPM rev limiter in the computer?????
You may be aproaching the rev limit and fuel reading may be affected by this. What is the AF reading at 4500 RPM?
Does it stay at 13.2 until 5000?
Another thing - what cam and valve springs? If you have a Torque cam you may be floating the valves at 5000 RPM and AF ratio will be affected.
Old September 30th, 2005, 06:55
Panama XJ's Avatar
Panama XJ Panama XJ is offline
Hesco Cam or stock Cam?? Stock valve runners or ported and polished??
Old September 30th, 2005, 09:22
XJJack XJJack is offline
Where are you instaling the sensor? It will make a diference as to how far down the pipe it is, and also if you are using the stock hole with the stock sensor out, the computer is tring to adjust but not getting the right info.
Old September 30th, 2005, 12:32
corbinafly's Avatar
It's not the rev limiter. The AFR drops as the rpms increase. So there is no sudden drop at the high end.
It was built by hesco with the h264 cam. I'm not sure about the valve springs, but I doubt hesco would build it without the proper springs. They would see the problem when they run it on their dyno before shipping.
K
Old September 30th, 2005, 12:33
corbinafly's Avatar
h264 cam, cnc ported head
K
Old September 30th, 2005, 12:37
corbinafly's Avatar
It's intalled in the bung provided by the Borla header for the stock sensor. The gauge sends a signal to the the PCM that simulates the signal from the stock O2 sensor so the PCM is happy. No DTCs.
K
Old September 30th, 2005, 15:51
opehesox opehesox is offline
Check out the PLX widebands, They are really good and inexpensive...
www.Englishracing.net has them for good deals
Old October 1st, 2005, 05:24
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Here's my setup:
95 XJ, AW4
WJ intake manifold
stock throttle body
K
The increasing richness as the rpm increase could point to restricted airflow or it could just be a quirk of the stock PCM programming. Replacing your stock TB with a 62mm unit would be a good start; you could even go for the Flometrics 66mm or 68mm unit and enlarge the plenum inlet opening to match.
Are you sure your injectors are only 21lb'ers? I would have expected at least 24's on a HO stroker. Even Hesco recommend at least 10% larger injectors than stock.
Old October 1st, 2005, 08:24
corbinafly's Avatar
Yeah. I think I'll probably go for a 66mm TB and new intake tube before I try anything else.
The accel injectors are the 21 lb'ers. I put them in myself and they have the 21 clearly marked on them.
Thanks for the input on the PCM programming "quirk". I wonder if that's the case.
Any other ideas anyone?
K
Old October 1st, 2005, 11:31
JJacobs JJacobs is offline
Looks to me like it's rich enough on top for a very small dry shot of nitrous to even things out.
Rate This Thread:
Weird rpm/speed readings...input? nosajwp OEM Tech Discussion 2 April 19th, 2005 19:28
SWR readings crookedletterd Modified Tech Discussion 8 January 29th, 2005 19:58
Weird TPS readings and high idle??? HEKULIINI OEM Tech Discussion 14 June 29th, 2004 15:24
high nox readings on emissions xjblaine OEM Tech Discussion 21 March 1st, 2004 22:53
1988 Renix TPS readings gator_grabber OEM Tech Discussion 16 February 24th, 2004 13:57
