Old November 6th, 2004, 18:51
97XJ 97XJ is offline
aux driving lights
I'm going to mount aux driving lights on stock XJ front bumper.Which would
buy Hella 550's or IPF 868's?
Old November 6th, 2004, 18:59
RichP's Avatar
RichP RichP is offline
Re: aux driving lights
Neither go with the 450's, smaller and put out the same light, look under the bumper in front of where the stock ones go, see that elongated oval hole ?
Use a drift pin to *gently* round it out then use a big washer on both sides of the hole when you put the stud thru for the light.
I've had both 550's and now have 450's, the 450's dont catch so much stuff off road...
Old November 6th, 2004, 19:14
nhrocker's Avatar
nhrocker nhrocker is offline
Jackstand wheeler
I have the Hella 550's and cant imagine driving without them. I live in New England so I drive in bad weather all the time. They'll cut through anything. But I knew I would take them out in the stock spot, so I mounted them in holes on the top of the bumper. They're much safer and look cooler too!
Old November 6th, 2004, 19:29
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
PIAA 510's at the very least. But that's just me.
anyone running fogs and driving lights? ylojelo OEM Tech Discussion 7 August 13th, 2003 07:57
? Aux Lights ? Fonzie14 Modified Tech Discussion 4 July 27th, 2003 12:59
replace OEM aux lights on front bumper JGXJ OEM Tech Discussion 1 May 3rd, 2003 15:27
Aux. Fan Works Only w/ AC?? DaveWV OEM Tech Discussion 5 April 5th, 2003 01:17
