Old December 9th, 2019, 13:26
Wheelin 4 life Wheelin 4 life is offline
New steering column, no break lights 91 xj
I've got a 91 auto xj, the old steering column was loose and one day it locked up on me while driving. So i got a new column out of a 93 manual xj and everything works but the break lights.
i read somewhere that the circuit for the breaks run though the cruise control at lease on the 91-94 autos. I have the old column so can i put cruise control in my new manual column?
I'd prefer not to tighten and use the old column cause of it locking up lol
Also ive looked for quite awhile and i guess in my area finding 91-94 columns in a real pain so i guess ive got to figure out how to use the manual steering column and make the brake lights work, any help is appreciated
Old December 10th, 2019, 10:25
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: New steering column, no break lights 91 xj
The brake lamp switch is connected to the cruise control so that stepping on the brakes disengages the CC.
The brake lamp switch is typically located on/near the brake lever arm above the brake pedal. It is logical to assume the steering column work either damaged the switch, damaged the switch wiring, or the switch is for some reason improperly adjusted.
I would start trouble shooting at the brake lamp switch.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
1992 (chrysler?) steering column in 1988 XJ (originally GM Column), possible? JonnyRo Modified Tech Discussion 4 December 28th, 2008 06:32
break away bosses on steering column support Skullver OEM Tech Discussion 0 July 16th, 2007 14:24
steering column major break found skipc OEM Tech Discussion 2 July 22nd, 2005 21:07
steering column = parking lights tony r OEM Tech Discussion 3 May 23rd, 2004 13:19
