Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Old June 4th, 2014, 13:40
gradon's Avatar
gradon gradon is offline
Innovate LM2 Wideband O2 Sensor/OBD2 Scanner/Data-logger in DC
For sale is a used:
LM-2 3806 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung, LogWorks software CD, and quick-start guide. Carrying Case also included!
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winning digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
  • Patented “Direct Digital” Wideband Technology
  • Wideband O2 Compatible with ALL fuel types
  • Single or Dual Channel Version Available
  • OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
  • Log directly to SD card (included)
  • Playback log data on screen and/or with powerful LogWorks software (included)
  • Large high-contrast graphics LCD
  • Built-in RPM converter (direct frequency or with optional inductive clamp)
  • 4 fully-differential analog inputs
  • 2 configurable linear analog outputs
  • Positive lock connectors for all connections
  • Innovate MTS serial IN and OUT
  • USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
$250 shipped from DC, 20010.
Old June 12th, 2014, 16:00
gradon's Avatar
$220
Old June 12th, 2014, 16:20
Root Moose's Avatar
Root Moose Root Moose is offline
Re: Innovate LM2 Wideband O2 Sensor/OBD2 Scanner/Data-logger in DC
I'll take it. PM me your address and I'll send you a money order. It'll be shipped to NY/13669.
Thx.
Old June 14th, 2014, 06:58
gradon's Avatar
Pm'd
Old June 26th, 2014, 07:17
gradon's Avatar
Sold!
OBD2 scanner XJensen Sierra Chapter 27 October 1st, 2011 14:17
what is a good OBD II scanner with real time data mmag1982 Jeep Street and Performance 11 September 10th, 2011 06:26
Played around with an LM2 wideband data logger today BlueCuda Jeep Street and Performance 16 August 3rd, 2011 19:29
Data Logger/code reader Johnnie Walker Non-Tech / Off Topic 3 February 6th, 2010 05:02
data logger... MountainRhino Modified Tech Discussion 7 January 10th, 2007 09:46
