Old May 10th, 2011, 08:57
coldoath coldoath is offline
Off road lights as driving lights?
Question: Can you use off road lights as normal driving lights? I know you wouldn't be able to get a high and low but jw.
Reason for question:
Old May 10th, 2011, 09:35
shawnhancel shawnhancel is offline
Re: Off road lights as driving lights?
would check with the local laws. but couldnt you just swap em out as needed. nice rig!
Old May 10th, 2011, 09:43
Would rather just leave the off roads in. I was kinda wondering if you could just angle them down and then have other off road lights for actual off road stuff.
sunburned sunburned is offline
Doubt it. Those guys obviously don't drive on the street much. Offroad lights don't have a cutoff so you don't blind the people in front of you.
Old May 10th, 2011, 09:47
Monster Mopar Monster Mopar is offline
^^ Totally agree with the above. Road lights have a beam cut off which prevent on coming traffic from getting blinded and crashing... possibly into you. I wouldn't do it, even if you aimed them down it'd still likely blind oncoming cars.
Old May 10th, 2011, 09:49
snail snail is offline
NJ DMV used to threaten to fail during inspection just for having forward facing offroad lights mounted anywhere on the vehicle, much less replacing the stock ones. It probably depends on local laws.
Old May 10th, 2011, 10:02
The orange Jeep has blinkers so makes me wonder if he found a way to make it work or maybe he just doesn't drive at night?
Found these:
http://www.4wheelparts.com/Lighting-...4730&t_pl=9695
Old May 10th, 2011, 10:48
Begster's Avatar
Begster Begster is offline
Found these:
The fact that the orange one has full hydro steering, and creepies for tires makes me tend to think that vehicle doesn't get driven on the street at all.
Old May 10th, 2011, 11:09
iwannadie's Avatar
iwannadie iwannadie is offline
Looks to me like both never see the street and wanted offroad lights. They had no need for street/factory lights so they filled the factory holes with offroad lights. Just my guess.
Old May 10th, 2011, 11:41
Rammin97 Rammin97 is offline
found this:
http://www.txdps.state.tx.us/vi/insp...rop=Head+Lamps
Old May 10th, 2011, 11:45
FlexdXJ's Avatar
FlexdXJ FlexdXJ is offline
My offroad lights are driving lights.
97 XJ, OME, JCR, HDOR "HObrid" cage blah blah blah... DD/trail rig, '66 M416 expo/truckbed trailer, 02 Subaru WRX wagon
[QUOTE=*89Laredo*;246072645]
The human skull makes quite a loud noise when it hits a metal chair.
[/QUOTE]
Old May 10th, 2011, 13:03
Darky's Avatar
Darky Darky is offline
Are you asking if you can replace your headlights with offroad lights? The answer would be no. Notice how both vehicles have cages replacing the stock front body work? As others have already said, chances are good they aren't street driven rigs.
Old May 10th, 2011, 13:53
Yea that seems to be the conclusion.
Hella makes these that have low and high beams: http://www.4wheelparts.com/Lighting-...4730&t_pl=9695
Guessing I could just use those if I ever decide to go this route?
Old May 10th, 2011, 13:58
Darky's Avatar
You mean you guess you could just use a DOT approved round headlight? Because that's what that is. That's a replacement headlight for a TJ or other round headlight vehicle. Much like the H4 upgrade for our XJs.
Old May 10th, 2011, 14:20
XJRunner's Avatar
XJRunner XJRunner is offline
my dads been running 55 watt KC daylights as headlights in his flat fender since he was 16. Just get the flutted lense and you should be ok. 55 watt is the highest power bulb you can legally have for headlights
Tail lights, Turning lights and Shifter lights STAY ON JSwamper OEM Tech Discussion 22 October 4th, 2011 18:20
driving lights where fog lights go xray1971 OEM Tech Discussion 24 May 16th, 2009 12:23
driving with off road lights on bmyohn North Atlantic Chapter 19 December 13th, 2006 19:21
aux driving lights 97XJ Modified Tech Discussion 3 November 6th, 2004 19:29
off road lights, spot lights dellstopjeep Wanted: Private Party Only 1 May 2nd, 2004 20:22
