Old November 20th, 2010, 11:40
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Beginning of 1993 Cheromanche build
Been home for a week and a half now and been sick most of the time I've been back. Posted a thread in the SEC but after over 50 views not a single person posted willing to help with any fab work. Trying to get in touch with watrousmark to see if i can get his welder again to get back to work on it. Been doing other things like getting rid of some of the rust on it and getting it primed up and stuff.
Old November 20th, 2010, 12:49
bosco01xj's Avatar
bosco01xj bosco01xj is offline
I know how ya feel. I've been sick for about the same amount of time. It's no fun.
Old November 25th, 2010, 14:48
There's a couple of pics of something i'm having a hard time wrapping my head around. I've got the frame's, roof, and floor lined up but having a hard time figuring out how I'm going to line up the rockers. Both the drivers and passenger side are like that as in the need to move out and down 1/2" to line up to weld them together. The only thing I've been able to think of so far for it is to order new rockers from rockauto then cut a couple of ~10" sections from it then cut these back and weld them in. If anyone's got an idea of how to get them lined up I'm all ears as this is the only major thing holding me up on hopefully finishing the project.
Old November 25th, 2010, 18:56
Root Moose's Avatar
Root Moose Root Moose is offline
- Flanging tool (check eastwood.com).
- sheet metal.
- router bits and router.
- various peices of hard wood and angle iron to make a impromptu brake in your vise.
- mount the doors for your reference points.
What to do with the above should be apparent and is left as an exercise for the student.
Don't waste your money buying panels that you are going to have to cut up anyway.
Old November 26th, 2010, 10:36
tbburg's Avatar
tbburg tbburg is offline
I think he's using custom sized back doors.
OP - You cut the two vehicles at different points( front of the front door openings/center of the rear door openings ) the problem is, most "straight" panels on a car are not truly straight, they have a slight crown or dish in the center.
Based on the pics, I'd probably try to separate the weld where the floor hits the rockers, tweak them so they line up, fill in the rocker panel,(probably have to tweak the width too) then finally re-attach the floor pinch seam.
Old November 26th, 2010, 13:58
Hemihed426 Hemihed426 is offline
Why somebody would want to do this is beyond me...........
Old November 26th, 2010, 17:35
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Looks like the vehicle sections are not truly parallel, remount the doors (any doors) so you have straight edges to line the back half up with.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old November 27th, 2010, 11:33
Root Moose's Avatar
Yep, but he needs to get the forward reference at the door to make it line up. He needs to remount the rear doors to get the geometry right. Even if he sections a set of rear doors to make it fit in the new hole... now would be a good time to look at what cuts are required to make the new doors.
http://www.naxja.org/forum/showpost....4&postcount=89
These Jeeps are not slab sided. There is a very slight taper from the back to the front. He needs to deal with that as the section at the front door opening is slightly wider and shaped differently compared the the rear door opening.
Old December 7th, 2010, 14:56
Here's how it sits in my driveway right now. Man working outside in winter sucks, temps in mid 30's for the highs this week and getting dark by 5 only leaves a half hour of daylight during the weekdays to work.
Here's the new seats that I'm going to be throwing inside of it, they came from a 98+ durango. Power drivers seat rear bench with fold down console, and seats tilt forward for access behind them (could be a good replacement for stock comanches to add comfort and functionality. Will have to custom make mounts but the fronts mount kind of like the 97+ seats do on the little raised bar in the front.
Think I've figured out what I'm going to do for the rockers. Planning on cutting them free from the floor then to move them down cut a slit from the bottom up at the back where it's almost in the back jam. That should allow me to take a sliver out and bend it down while keeping the opening pretty close to the same. Then to spread them out the inside is pretty close so i think I'm going to cut a slit along the top of the rocker back to about the same point as the first cut then spread the outside part out to line it up. Then use some sheet to make a patch to fill it in as all that will be under the black plastic piece that is in the bottom of the door openings.
Old December 7th, 2010, 15:27
John D's Avatar
John D John D is offline
NAXJA Member # 788
Yeah, this must be really hard on you
Old December 7th, 2010, 15:53
go1lum go1lum is offline
Hehe x2
I don't even see any snow on the ground.
Old December 7th, 2010, 17:43
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
lol, It's rough on someone that's not used to it. The high here was 32* and the low was 12* today. I thought I was going to turn into a Popsicle on my lunch break in the smoking area outside.
Old December 7th, 2010, 18:02
Hehe, I live in N. Michigan. We get tons of lake affect snow. Actually we already have about two foot.
Old December 7th, 2010, 18:08
Lowrange2's Avatar
Member# 2368
I saw about 6" of snow last year up in the foothills in SC about 30 miles from the SC/NC border. That's the most snow I've ever seen.
Old December 7th, 2010, 18:13
Your missing out. Should take a trip up to my neck of the woods and we can do some winter wheeling. Nothing like blazing through the trails in four to five foot of the white great stuff.
Tubewerk- the beginning... bcmaxx Modified Tech Discussion 10 April 21st, 2010 22:17
Gun Certification is Beginning Ecomike Political Discussion Zone 28 August 10th, 2009 22:11
1993 2 door build opinions? Fromagnon Modified Tech Discussion 8 April 30th, 2008 22:49
beginning exo Fullsizexj Modified Tech Discussion 14 January 4th, 2004 02:09
