Old September 8th, 2010, 13:34
anthrax323 anthrax323 is offline
Re: Beginning of 1993 Cheromanche build
That would be an awesome little super-SWB rig, along the lines of a Samurai.
Old September 9th, 2010, 09:40
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
That would be cool with the wheelbase stretched out for 0 approach/departure angles.
Old September 27th, 2010, 10:12
scott00tj's Avatar
scott00tj scott00tj is offline
Any updates? I'm loving the build. Have you thought about rear steer since its so long?
Old September 27th, 2010, 15:56
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
No rear steer will be normal in every aspect except the length. I've gotten the roof almost finished just have to finish welding a few spots then grind it smooth. Working on getting some sheet metal to start forming the floor board, and getting the doors cut and spliced together. Still trying to source a 2 piece shaft for it as would rather pick one up in a JY rather than pay close to $600 for a custom built unit from high angle driveline.
Old September 27th, 2010, 16:52
John D's Avatar
John D John D is offline
NAXJA Member # 788
Try looking for a 2WD long box extended cab truck. The Chevy 1500s are a 2 piece with carrier support. May be a good starting point for length.
Old October 19th, 2010, 19:36
bosco01xj's Avatar
bosco01xj bosco01xj is offline
so... is this project dead or what?
Old October 19th, 2010, 20:03
No not dead it's still sitting in my driveway. Been traveling for work quite a bit since the project started. Originally wanted to have it done and back together by halloween, now I'm hoping I can stay home sometime to be able to get it done by thanksgiving. Been in DC, NYC, and now San Fran/Oakland since the project started. I've gotten the roof set in place and half way welded in place just need to finish welding it up. I got the 18GA sheet for the new floor pan and some 10GA 3" angle 8' long pieces to build some frame stiffeners. Just have to get home and be home long enough to get some work done. Not supposed to be home until 11/5 so right after that I'm gonna post up a call in the SEC to see if I can get a few people with grinders, cut off wheels, and some good fab skills to hopefully get quite a bit done.
Old October 20th, 2010, 09:35
jeeperjohn's Avatar
I wish I could come out there and help you. I have family in KY I would love to visit and also come down there for a couple days but alas, I am poor
Old October 20th, 2010, 11:57
casm's Avatar
casm casm is offline
I really like this build, and am looking forward to seeing the end result - 4-door MJs have always had an appeal to me that I can't quite explain
Kinda related to this: has anyone seen a 2-door XJ front grafted onto an MJ rear? There's something equally-appealing about an extended-cab Comanche with a little more room behind the seats for gear and stuff you don't want exposed to the elements.
Old October 20th, 2010, 16:09
http://www.comancheclub.com/forums/v...=25496&start=0
There's one to keep an eye on as he's planning on doing just that with a 2dr xj.
Old October 20th, 2010, 17:08
John D's Avatar
NAXJA Member # 788
Looks like he lost interest, last post is 2 years ago.
Old October 20th, 2010, 17:49
casm's Avatar
Sad to see it - it's an idea that really seems to have merit.
Old October 20th, 2010, 18:28
He didn't lose interest the last post was oct. 10th of this year.
Post subject: Re: MJ/2dr xj shortbox. code name payote
Posted: Sun Oct 10, 2010 6:51 pm
Old October 20th, 2010, 18:46
casm's Avatar
Right, but in his words:
Originally Posted by tazjeeper
well as things go around here I have an other yj 360 swap to do.. but on a good note i bought a tj, 74 wagyy and a cj... oh and a yj
so this project is on hold till the customers yj is done..
So it's stalled, but he'll pick it back up. No worries.
Old November 20th, 2010, 10:18
bosco01xj's Avatar
so... what's going on with this build?
Tubewerk- the beginning... bcmaxx Modified Tech Discussion 10 April 21st, 2010 23:17
Gun Certification is Beginning Ecomike Political Discussion Zone 28 August 10th, 2009 23:11
1993 2 door build opinions? Fromagnon Modified Tech Discussion 8 April 30th, 2008 23:49
beginning exo Fullsizexj Modified Tech Discussion 14 January 4th, 2004 03:09
