Old September 1st, 2010, 17:18
Jeepman Jeepman is offline
Re: Beginning of 1993 Cheromanche build
Awsome So far I look forward to seeing where this goes...
Old September 1st, 2010, 18:48
Team Willys's Avatar
Team Willys Team Willys is offline
www.rocksolidfab.com
Originally Posted by dave92cherokee View Post
It's going to be a street only DD rig so it'll be lowered a couple of inches past stock with some 20's and 255/45/20 tires, stiffer suspension, 4.10 gears, and someday down the road a 4.7 stroker.
Wow, that's a lot of vomit... I think its gonna look stupid long. But... I am looking forward to seeing it done and maybe you will prove me wrong. For the Jeeps/Trucks sake I hope you do!
Old September 1st, 2010, 19:47
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Ahh, Put a 3 inch lift and some 33's on it. With it that long and low with 20's you're going to get high centered on driveways or speed bumps... speaking from experience here...
Old September 2nd, 2010, 09:57
bwinter1946 bwinter1946 is offline
Originally Posted by Kittrell View Post
I almost feel obligated to post this. Still not quite sure what length you are after here, but this is what it would look like with the stock short bed and a proportionally sized rear door.
That truck is beautiful. Really nice!!
Anybody know if there are more pics somewhere and more info on it?
Old September 2nd, 2010, 10:03
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
It's a photoshop, and the author of said photoshop posted it
A very well done one, every time I see it posted... people ask for more pics. No one even realizes it's a photoshop till they see it next to the full collection of other versions (other colors, door lengths, bed lengths, etc) and it always seems to pop up when someone starts a 4 door MJ thread...
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old September 2nd, 2010, 11:44
Ah.. Thanks Kastein. They did a nice job with the photoshop.
Old September 2nd, 2010, 15:31
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Originally Posted by John D View Post
Go V8, you'll be happier...
x2 You have already gone this far. Hit it out of the park.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 2nd, 2010, 16:37
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
As for the driveline I'm not sure exactly what I plan on doing with it. It will receive attention down the road sometime though. Would love to make it into a sleeper and slide a V8 in it but then all the wiring will have to change.
This holiday weekend hoping to get quite a bit more done but will see how it actually pans out with spending time with the family before I leave for work again. Hope to get the rest of the welding done on the frame so I can get it off the jackstands then start working on everything else. When doing the roof I also plan on filling in the holes from the luggage rack to smooth everything out and give it a cleaner look. Hope to get the rest of the rotted floor of the XJ cut out and get it prepped for new floor. Would like to get rockers put into alignment and get them started.
Old September 2nd, 2010, 18:47
John D's Avatar
John D John D is offline
NAXJA Member # 788
This part isn't as hard as you think...
http://www.lt1swap.com/
Everything you need to know about building an LS harness is in there.
Lowering it and clearing the oil pan on an LS motor, now that would be tricky.
Old September 6th, 2010, 14:16
Took a break from welding on the jeep while it was a little hot outside. Finally got it so it can rest on it's wheels and off the jackstands. Have one more piece to add to the frame to finish getting it together. Got the top of the doors welded together and part of the roof welded from the xj to the back of the mj. Will get pics posted up later after smoothing out the rest of the welds. While taking a break decided to go in the backyard and have a little fun with the leftovers which yielded this picture. Anyone have any thought or inspirations?
Old September 6th, 2010, 14:55
John D's Avatar
NAXJA Member # 788
Actually, I would be more interested in seeing this project than the long one
Old September 6th, 2010, 15:07
Stallacrew's Avatar
Stallacrew Stallacrew is offline
Yeah I have a bent up body laying around that I might try this out on one day.....only thing is that with such a short distance between the tranny and rear axle, you would have to run an old school short 4 speed without a transfer case so you wouldnt bind your driveshaft.... Either that or or do IRS....or....something?
Looks alot like a bronco II mixed with a Sami.
Its not how fast it will go, its how fast it gets to how fast it will go.
Old September 6th, 2010, 15:09
94xjstud 94xjstud is offline
You could do a comp cut, move the rear axle back some and maybe end up close to a cj or wrangler wheel base.
Old September 6th, 2010, 15:50
Ok some progress pics from the weekend. Got to work on it and got the passenger side pulled together and then welded in place. Lifted the back of it and got the roof lined up and welded up. Now it will be a couple weeks before I get to work on it again as I'm getting sent back to DC again for a week and a half for work. But I am no able to see it standing on it's own wheels and under it's own weight without any jackstands. Checked the wheelbase and it has a wheelbase of approximately 147" which isn't as bad as I thought it was going to be.
How it is currently sitting in my driveway.
Pic of passenger side frame and rockers. Frame is welded then a 1x2" angle plate 9" long welded on top of the spliced frame.
Pic of floor that has been cut away to have new metal formed. You can see in the pic the floor has a support piece by the splice that goes from the floor to the rocker. Once I remove this support piece I should be able to bend the rockers down to have them match up with the rockers from the XJ.
Pic of the roof pinch seam welded together. Went ahead and threw some flat black on it to prevent any rust from forming while I'm gone.
Old September 8th, 2010, 13:11
moto_ridah moto_ridah is offline
Weld them together, take the front axle/suspension off and turn it into a mini trailer for the Cheromanche to pull.
Tubewerk- the beginning... bcmaxx Modified Tech Discussion 10 April 21st, 2010 23:17
Gun Certification is Beginning Ecomike Political Discussion Zone 28 August 10th, 2009 23:11
1993 2 door build opinions? Fromagnon Modified Tech Discussion 8 April 30th, 2008 23:49
beginning exo Fullsizexj Modified Tech Discussion 14 January 4th, 2004 03:09
