Old April 6th, 2010, 18:18
wy_jeep wy_jeep is offline
Valve cover bolt and driveshaft strap bolt size...
Can anybody tell me what size these are? I need two valve cover bolts (fastens valve cover to the head) and two drive shaft strap bolts (fastens straps to hold driveshaft to the rear axle). I took one of each to compare to hardware stores and ended up losing them.
Thanks!
Old April 6th, 2010, 18:24
joe_peters joe_peters is offline
Re: Valve cover bolt and driveshaft strap bolt size...
Year/engine/trans/transfer case/axles?
Partial listing on 5-90's website: http://www.geocities.com/JeepI6Power/screws.html
Old April 6th, 2010, 18:46
95, 4.0L, AX15, 231, D30 and 8.25. I checked link and didn't find anything older than 90.
Old April 7th, 2010, 05:45
cruiser54's Avatar
cruiser54 cruiser54 is offline
Might be time to grab a coupla more samples off your rig to take to the store............
Old April 7th, 2010, 09:42
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I'd hit the junkyard and swipe a couple.
Driveshaft bolts are 3/8-24 UNF iirc, I'm not sure on the valve cover bolts. They should be the same on any 4.0 though.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old April 7th, 2010, 11:22
MoparManiac's Avatar
MoparManiac MoparManiac is offline
5/16-24 I thought...?
Old April 7th, 2010, 11:24
kastein's Avatar
yeah... you're correct. My mistake.
I think 5-90's page has the valve cover bolt size but I am not sure, it's already been posted.
Old April 7th, 2010, 16:57
doktor_x doktor_x is offline
The valve cover bolts are 1/4-20 on my 2000. I'd imagine they're the same for any 4.0.
Valve cover bolt hole leaking coolant? Robs92XJ OEM Tech Discussion 4 June 10th, 2016 00:19
Which tap size to chase the threads in the valve cover bolt holes? 92DripCherokee OEM Tech Discussion 4 February 15th, 2014 22:37
REAR valve cover bolt TIPS? Rocketman OEM Tech Discussion 6 January 28th, 2006 17:21
D30 Cover Bolt Size/Length Rocketman OEM Tech Discussion 3 January 12th, 2006 18:03
HELP!! valve cover bolt broke off cykaaro OEM Tech Discussion 12 September 6th, 2005 00:10
