Old February 25th, 2010, 18:38
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Sway bar bracket bolt size?
What size are the bolts that secure the front sway bar brackets to the unibody? I need to grab some hardware in the morning for a couple of Jeep projects, but all I've come up with is the part number- 3420 1540. I think it's M12, but I don't know the thread size, or even if it's M12. I've searched, googled, and checked a parts catalog, but I haven't found anything to confirm the size/thread. Can someone help me out here?
Thanks,
Chris
Old February 25th, 2010, 19:09
CanMan's Avatar
CanMan CanMan is offline
Re: Sway bar bracket bolt size?
IIRC they are M10, 1.25 on the threads.
Not 100% though, can measure in the AM.
Old February 26th, 2010, 06:48
hubs97xj's Avatar
Don't want to tear it down in the driveway at the moment (since I have to drive it to get parts), but it looks like M10x1.5 thread, which seems to be pretty common on the heeps. Surprised that I didn't find it in the many sway bar/drop bracket/stock skid threads.
Old February 26th, 2010, 11:37
joe_peters joe_peters is offline
I've had some success when trying to locate bolt/nut sizes by checking out aftermarket manufacturers websites. Look in the installation instructions--if posted online--they usually have a parts list with hardware details.
Using sway bar bracket as BPE bad idea? northwestxj Modified Tech Discussion 4 November 24th, 2009 20:01
Sway Bar drop bracket Qs rooneypower Modified Tech Discussion 1 March 19th, 2008 18:31
WJ Knuckle- Caliper Bracket Bolt Size, Teves. RyanM Modified Tech Discussion 2 November 23rd, 2007 17:49
Stock Front Brake Line Bracket Bolt size? Cherokeekid88 OEM Tech Discussion 0 October 15th, 2007 11:58
sway bar drop bracket diabloxj Modified Tech Discussion 11 January 31st, 2005 02:25
