Prev Previous Post   Next Post Next
  #16
Old December 2nd, 2019, 13:41
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Where to mount my wideband O2 sensor on my 2000 XJ?
Originally Posted by bajabronco View Post
LazyXJ -I have the same headers as well.
I am still thinking of going before the cat. Have you found a big deviation in the readings between the front and rear banks on your two wide bands?
The wide-band O2 sensors must go before the catalytic converters to get an accurate reading of the mixture.
I notice no major differences in mixture readings when switching from one sensor to the other.
Fuel trim levels can be read with OBDII monitor, such as a ScanGauge or Ultragauge.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Swapping to Wideband O2 Sensor CorneliusRox Modified Tech Discussion 8 February 24th, 2017 11:11
Innovate LM2 Wideband O2 Sensor/OBD2 Scanner/Data-logger in DC gradon For Sale: Private Party Only. XJ ITEMS ONLY 4 June 26th, 2014 07:17
2000 XJ 02 sensor md11fan SoCal For Sale 0 July 17th, 2010 00:07
Cam Sensor on 2000 XJ steveybass OEM Tech Discussion 10 January 4th, 2010 20:21
AEM wideband O2 sensor/gauge readings corbinafly Jeep Street and Performance 12 October 1st, 2005 11:31
