Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old January 10th, 2019, 17:35
JeepNoob JeepNoob is offline
Removing old paint.
Well, some people just seem to gravitate to Jeeps... You know the ones I'm talking about...
Bought an '89 XJ for dirt cheap. It was probably pretty sharp when it was new, fire engine red with chrome exterior trim.
Aaaaaaaaand then some mental midget decided to come along and put truck bed liner all over the hood and give the rest of it a flat-black, murdered out, rattle-can job (trim included) that of course is now peeling and flaking off and just looks ugly. Now, I could just give it 5 years or so and let the Colorado sun do it's thing, but does anybody have any ideas on how to speak up the process without affecting the underlying factory paint TOO much? I figured taking a light grade of steel wool to the bumpers should take that stuff off without scratching the chrome up too much. I'm stumped on the rest enough...
Old January 10th, 2019, 18:32
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Removing old paint.
Power washing the living f out of it?
You could also try wet sanding the paint but not sure how effective it will be. If there was no clear underneath the rattle can it will be a lost cause.
You're better off stripping it down and re shooting it if you want it to look decent. Aircraft remover works amazing, but it can be messy. I would at least try it on the chrome parts.
Old January 28th, 2019, 16:40
Whoops! Turns out at least some of this "paint" (especially around the hood) is just really crappily applied truck-bed liner. Popped the hood tonight with a can of VatoZone carb cleaner sitting on the driver's side cowl (checking for vacoom leaks.) As soon as I did that, I heard a God-awful hissing noise. Think like a radiator cap that you just opened while still hot. While looking around thinking I somehow severed some sort of major artery, I caught the smell of solvent...
Yep, I punctured the can pretty much exactly where you would punch a hole in a beer to shotgun it, and before I knew it, I had dumped about $4 or $5 of carb cleaner all over the Jeep lol. As the saying amongst my people goes "Ope! (pause) Oh well..." As I was cleaning it up however, I noticed the paint/bed liner was peeling off without affecting the underlying paint too much. It left a pretty gummy residue, but I think with more elbow grease, I could clean that up too.
what paint you guys using to paint an AXLE MUKAK714 Modified Tech Discussion 49 July 28th, 2014 15:12
Removing rattle can from OEM paint Lurch Paint and Bodywork forum 14 December 21st, 2013 09:48
How to paint leaf springs and coils? What paint? Jeep450r Paint and Bodywork forum 11 August 26th, 2009 09:46
Removing the side moulding and spray paint XJfire75 Paint and Bodywork forum 3 March 23rd, 2009 12:04
Removing adhesive from paint. jeepboy381 OEM Tech Discussion 14 August 28th, 2007 19:58
