brake switch help
bcmaxx
swapped in 2004 grand cherokee brake booster, kinda buggered up how the stock switch mounts and works:doh: , any alternative switches or ideas for a switch? I (just to get home) put the brake lights on a rocker switch,it's my dd.
Swap the rod from your stock one into the WJ one.
or
Fill the edge that you ground off with weld and grind again, correctly.
or
Cut the end off the stock XJ one and off the WJ one and weld the XJ one onto the WJ rod.
or
Have fun with your rocker switch.
Thanks for the help, went with a tee and a pressure switch.
