FJH97XJ
- Staten Island, New York
I'm installing The Bushwacker flares in the rear but I want to install a steel rod between the gaps of the rear quarter panel & the wheel well. I'm using a MillerMatic 210 w/ .030 wire. What settings should I use as far as temp. & wire speed & also tips to weld the rod without burn thru. Thanks
