Old May 16th, 2018, 08:35
mchulse mchulse is offline
2wd front hub axle stub torque
I'm almost done on my 2wd 2001 XJ front ball joint and wheel hub replacements. I've seen the torque specs for the 36mm axle nut is 175 lbs but it seems pretty high for a 2wd axle stub that serves limited purpose. Also, the axle nuts came off with relative ease so I'm curious if the torque was that high originally.
Does anyone know if that torque spec is correct for a 2wd front axle nut?
Also, more for curiosity sake, what purpose does the axle stubs serve and what could happen if under torqued?
Thanks!
Old May 16th, 2018, 08:58
RCP Phx RCP Phx is online now
Re: 2wd front hub axle stub torque
Torque should be the same, it's the unit bearing that your holding together!
Old May 16th, 2018, 09:22
Thanks RCP Phx, makes sense to me!
I had a tough time finding the part # for the nut kit. I ended up ordering the Dorman 05101 Spindle Lock Nut Kit. It says it only fits 4wd but my understanding is that part should be interchangeable between 2wd and 4wd. Once I get it in I'll see if it fits and update.
Old May 16th, 2018, 13:23
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
It's exactly the same unit bearing either way (on 92.5 and later... 92.0 and down you would be correct, they use a spindle that takes very low torque, but also don't have a stub shaft) so yes, 175 foot pounds is what you want to use.
Should be the same axle nut for 4wd and 2wd... again 92.5 and later, of course.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old May 16th, 2018, 15:28
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
A word of advice. If you're using a Harbor Freight torque wrench rated to 150 ft lbs, don't take it to 150 and then try to give it a little extra oomph with the same wrench. It'll break. Of course, no one would be stupid enough to try that. Right?
"Nothing is so invertebrate in nature as the worm of a lie that has been stepped on by the iron boot of truth." (Raezer v. Raezer, 428 Pa. 163, 166 (1968) (opinion by Justice Musmano).)
Old May 17th, 2018, 07:01
It actually doesn't sound like a bad idea... in theory. I do have that same HF 150 ft lbs torque wrench and opted to rent one from Autozone that goes up to 250 ft lbs since this is about the only job I can think of that will need to go above 150 ft lbs and I was renting a ball joint press, power steering pulley puller, and steering wheel puller (I've been busy).
The real problem I'm going to have to figure out is how to get it torqued without the wheel on. Many years ago I replaced my wheels with 17" Liberty wheels. They look great but the center cap opening is not big enough for either of my 1/2" 36mm sockets. I got the nut off with an impact, thinking "I'll deal with that later". Well it's later (Future Mike always get's screwed by Past Mike)
I've seen people put a tire iron or crow bar between a couple wheel studs and the ground to hold it while torquing them down. Not super keen on this idea as I'm afraid I'll mess up the threads on my new hubs (maybe wrap the crowbar in a towel?)
Another idea is to start the engine and have my wife apply the brakes while I torque them down. Maybe a combination of both might be good?
Old May 17th, 2018, 07:11
Nimrod's Avatar
Degenerate Jeeper
Not admitting I did actually break a HF torque wrench by exceeding its rating limit, I will say that my GF got me a really nice 250 ft lb torque wrench for my birthday. So I scored there!
I'd think that torquing with the brakes applied should do the trick even without a bar against the studs. But if you do go the bar against studs route, maybe stack some lug nuts on the studs to prevert direct contact between the bar and the threads. It might even protect the studs somewhat from the risk of bending.
Old May 17th, 2018, 07:25
Nice! A 250 ft lbs wrench for your birthday win (I was a little curious if the hub would get messed up from over tightening or if the wrench would break from exceeding it's spec)
Thanks for the advice on stacking some lug nuts on it. I might double up and have my wife apply the brakes while I also secure it with that method.
Now I just need those new axel nuts to come in and I'll be back on the road; at least until I get into upgrading the steering components, doing a rear disk brake conversion, and adding a powertrax no-slip. My 2wd XJ is too big to fail at this point so the only logical thing is to keep putting money into it.
Old May 17th, 2018, 07:26
I use a piece of angle iron that's drilled for several wheel patterns, flywheels, and u-joint yokes. As for torque, I built a "extension bar" that can be used with a hammer on the trail. It can be used with anything 1/2" drive.
Old May 17th, 2018, 07:53
Took me a minute to figure out how that would work but seems like a pretty handy piece of equipment. Something you welded yourself?
Old May 17th, 2018, 08:07
Yes , I made that for trail fixes! It's a 2x multiplier(12") so with my body weight of 150# and at 24" out I deliver 300ft/lbs, been doing bugs that way for 50yrs!
Old May 17th, 2018, 08:20
It's my version of one that's been around for 50+!
Old May 18th, 2018, 21:35
lawsoncl lawsoncl is offline
Last time I had to torque something to 275-ft/lbs, I used a 3-ft breaker bar while standing on cheap spring bathroom scale and just pulled up until it read 92 lbs heavier. You can also do the math and measure where on the breaker bar you need to put your full weight.
Old May 20th, 2018, 05:43
kastein's Avatar
Slap a rotor on it and jam the thickest chisel or screwdriver that will fit into the rotor vanes, spin it till it hits the caliper mount, torque nut to spec.
Old May 20th, 2018, 19:18
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
What he said. Thats how we do them at work. A good stout #2 screw driver works very well. Make sure the metal shank contacts the brake.caliper stuff, and the screw driver won't even be worse for wear.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Stupid question... front U-joint without removing axle stub nut? Crashsector OEM Tech Discussion 26 March 30th, 2013 12:37
WTB Dana 30 outer stub axle truck7575 Wanted: Private Party Only 2 March 17th, 2011 03:39
WTB Dana 30 outer stub axle truck7575 SEC For Sale / Wanted Forum 0 February 19th, 2011 07:07
In need of Non ABS D30 Axle Stub Stock98 SEC For Sale / Wanted Forum 1 June 13th, 2010 16:07
where to buy 2wd stub axle 4Doors JeepSpeed, Prerunner and Competition Tech Forum 9 January 27th, 2010 08:41
