Hi,
Is there an ignition-switched +12 lead somewhere underhood on a '90 4.0?
I'm wiring in an aux cooling fan underhood, and looking for something I can use to trigger it on only when the ignition is on. I'd like to avoid trying to wire to the interior fuse box as the "empty grommets in the firewall are already stuffed with other wiring, plus it'll be much tidier this way.
Thanks!
Thanks!
