Old May 15th, 2018, 17:12
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Blocking airflow to center console duct
Every time I have to yank out the center console in my '99 I say to myself, "self, that hvac duct that runs through there serves no useful purpose and is always in the way when working on stuff." Then I go on to say, "the next time I've got this console off, I'm gonna yank out that duct and just plug the hvac outlet that feeds it." Sometimes I don't actually say it aloud, but the thought always runs through my head. Anyway, the center console is out at the moment so today's the day. Or maybe tomorrow.
I've got a couple of ideas for how to plug the hvac outlet, all pretty simple and unlikely to result in fire or other catastrophe, but I'm wondering how others have done it. Maybe there's some kind of standard method that been used successfully hundreds of times and I haven't thought of it. So I'm asking: how have others blocked off the airflow to the center console duct?
"Nothing is so invertebrate in nature as the worm of a lie that has been stepped on by the iron boot of truth." (Raezer v. Raezer, 428 Pa. 163, 166 (1968) (opinion by Justice Musmano).)
Old May 15th, 2018, 19:15
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Re: Blocking airflow to center console duct
Cut out a piece of plastic, duct taped it over the hole
John V.
Director at Large
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old May 16th, 2018, 03:42
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Saw end off of duct, duct tape duct closed.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old May 16th, 2018, 08:20
TRCM's Avatar
TRCM TRCM is offline
Think I'd rivet something over it.
Over time, duct tape, even as awesome as it is, will dry out and come apart (glue mainly), especially inside a vehicle where it gets hot.
Old May 16th, 2018, 08:25
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
I think what I did was to keep the wide portion attached to the lower dash and cut it where it starts to narrow. I then used hot glue, silicon, or something else to attach another piece of the unused duct to the hole.
This helped me because it filled the gap that was showing through the front of my late model console swap and made it look much better.
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Loganís ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE)
99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc
93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (FOR SALE)
92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console
Old May 16th, 2018, 08:36
RCP Phx RCP Phx is online now
Total seal and easily removed if you change your mind later.
https://www.walmart.com/ip/GREAT-STUFF-Big-Gap-Filler-12-Oz/17300795?wmlspartner=wlpa&selectedSellerId=1122&ad id=22222222227025378678&wl0=&wl1=g&wl2=c&wl3=42978 127832&wl4=pla-81470065472&wl5=9029983&wl6=&wl7=&wl8=&wl9=pla&wl1 0=101593696&wl11=online&wl12=17300795&wl13=&veh=se m
Old May 16th, 2018, 12:45
Nimrod's Avatar
Degenerate Jeeper
Thanks for all the suggestions.
I went ahead and cut the “connector” end off the duct and wrapped it with duct tape and then stuck the taped-up stump in the outlet. It looks like it’ll seal pretty well. But having read the last couple of posts, I think I’ll yank it off and fill it with spray foam, which I happen to have on hand anyway.
removing dash center air duct? snail OEM Tech Discussion 5 July 25th, 2009 19:20
Looking for 97+ center console redneck Arizona For Sale/Wanted 0 July 9th, 2007 01:06
center console phurealdeaux Modified Tech Discussion 2 June 19th, 2006 07:35
Center Console for an XJ Big Ruff Toys 4x4 For Sale: Private Party Only. XJ ITEMS ONLY 0 January 4th, 2004 20:37
