Old May 9th, 2018, 18:16
stockrock stockrock is offline
98 xj door lock problems
My door locks don't work when the keyless entry module is plugged in when I remove the module the locks will unlock only . if I push the switch to lock position the doors unlock when the I push the switch to unlock it unlocks . I can bypass the switch and lock the door . I replaced both l/r door switches . it seems like the switches default to unlock only when the keyless entry module is removed am I right. this is driving me crazy
Old May 9th, 2018, 19:32
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: 98 xj door lock problems
how are the batteries in the fob ?
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old May 10th, 2018, 03:34
I don't have the fobs . I'm just trying to use the interior lock switches .
Old May 10th, 2018, 03:46
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Wire harness issues in the drivers door and the tailgate are very common. Begin with some basic trouble shooting, visually inspect the wire harnesses for damaged wires, chafed wire insulation, and failed wire splices. Test wire continuity. Test the locking solenoids by applying 12 volts directly. Clean and lubricate the locking and latching mechanisms.
The keyless entry module should have no effect upon the electric locks, unless it has its own issues.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old May 10th, 2018, 10:57
I repaired the harness in the drivers door. I pulled the harness from the the passengers side and inspected the wires and found a small crack In 1 wire I repaired that . I will go over the harness see if I missed other damaged wires . I will check the lift gate harness .thanks
Old May 16th, 2018, 10:32
found the problem the lock and unlock wires were cut behind the drivers kick also the new passengers switch is bad . I put the old switch back in all is good thanks for the help .
Drivers door lock switch- unlocks, but no lock? IslanderOffRoad OEM Tech Discussion 9 December 9th, 2014 03:49
passenger door set to lock but wont lock? jacksonbase OEM Tech Discussion 2 September 11th, 2013 09:10
Door Lock Problems - Alarm Install Secshunate Modified Tech Discussion 3 December 18th, 2007 12:48
WTB: door latch assembly, DS, 1997+ & door lock panel on door selarep Wanted: Private Party Only 1 May 3rd, 2007 22:22
power 4 dr. lock kit... on a 2 door... where to put the 4th door lock? selarep Modified Tech Discussion 2 April 22nd, 2007 20:52
