Old May 15th, 2018, 15:41
old_man's Avatar
old_man old_man is offline
Re: Renix crank no start
Originally Posted by ljobbins View Post
Itís starting now and running for 10-20 seconds at a time. Idles fine for a few seconds then starts a slow surge to drop until it dies. I have had a bad iac once and it doesnít do the normal fast surge. Fuel pressure is 35 at idle and jumps to 40ish with a fast opening of the throttle. Fuel pressure never drops.
Put a vacuum gauge on it. You may have a plugged CAT.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 15th, 2018, 16:35
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Also make sure the distributor shaft does not move side to side or rotate, It should be tight (bearings and drive gear..). Old_man has great suggestions too!!!!
But I think the newer NGK plugs are better. But even crappy brand plugs should fire and start.
Vac gauge would tell you if the Cat is plugged, once it runs for 10-20 seconds.
Have you checked the B+ relay yet, and contacts....it trips a timer that lets the ECU reset the IAC for the next start. It is critical for the IAC-crank-start cycle
I think Cruiser54 has a good write up/images on this
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old May 15th, 2018, 22:19
ljobbins ljobbins is offline
How fast can a cat go bad? The entire exhaust from the down pipe back is a year and half old give or take.
Old May 15th, 2018, 22:21
I swapped relay positions with no change. The contacts look clean as well.
Old May 15th, 2018, 22:23
I’m in Baja and I’ll have to run up to the USA in the morning to find ngk plugs. I have had better success with them as well.
Old May 16th, 2018, 10:37
Ecomike's Avatar
NAXJA# 2091
Very fast if the cat sees too much fuel from a rich operation. It super heats them and breaks the honeycomb into pieces that flop around and block the exhaust, or melts the face blocking exhaust. Or road hazard damage? Otherwise in normal healthy use way over 100,000 miles
Old May 16th, 2018, 14:04
It starts. It runs.
This morning my mechanic buddy came over to help me and we started it up and it died and we looked all over and checked several things(everything) and nothing changed. It would start fine and run perfect for 5-10 seconds then start a super slow surge. It would slowly surge up then down until it died. We started it probably 15 times and then one time it didn’t die. It still surged slowly but didn’t die. After 5 minutes of wiggling wires and unplugging things and testing vacuum and fuel pressure we turned it off and started it again and it surged a little less and did not die. Stopped and started it again and it ran perfect. It now continues to run perfect. Test drove for 20 minutes and started and stopped the engine 20+ times and it’s back to normal. So things we did to fix it...
1 Got confused
2 Got frustrated
3 Gave up and stared at the engine
4 Started it one last time
It works!
Renix can be so frustrating when everything seems to test fine and then you magically do something or hit a loose something and it works but you can’t pinpoint it or duplicate the situation. Thanks for the help and if anyone has more things to check or test to find my mystery problem in case it comes back please post it up. Thanks again.
Old May 19th, 2018, 05:00
Ecomike's Avatar
NAXJA# 2091
Indeed, I have learned that one can never have too many test tools for them, or run too many live, and unpowered hardware tests. My last nightmare was slowly dying shear pin/role pin that holds the dizzy gear on the dizzy shaft, it was letting the rotor position get sloppy on location.....as I accelerated and decelerated causing back fires. It was one I have never read or heard of here.....like many others I figured out over the years that were not in the FSM or....
Renix crank, no start issue brolly OEM Tech Discussion 10 September 4th, 2016 08:19
[Renix] No Crank, No Start desertred OEM Tech Discussion 12 May 24th, 2015 19:22
'88 Xj (Renix) - Crank, No Start RAVC1 OEM Tech Discussion 23 December 26th, 2012 15:50
Cooling system flush now crank/no start -Renix Johnnie Walker OEM Tech Discussion 9 May 15th, 2009 22:25
Renix won't start, doesn't even crank. overflow OEM Tech Discussion 7 April 13th, 2009 14:00
