Old April 27th, 2018, 17:29
trippled trippled is offline
Re: Hood vent design debate
The way I see it, they're not some be all end all thing. But if they offer some relief for whatever then I'll take that. If the stock cooling system is fine then you don't need that high dollar aluminum radiator and high flow water pump right?
I have a small set of vents on mine. Been on there for like 10 years. Ive lost 1 tps in that time a couple years ago. And yea the vents get insanely hot. After a quick drive the whole hood can be covered in snow except for the vents.
Old April 27th, 2018, 21:25
Greenz's Avatar
Greenz Greenz is offline
Originally Posted by Rockwood View Post
Classic embrittlement.
https://en.wikipedia.org/wiki/Embrittlement
https://en.wikipedia.org/wiki/Therma...on_of_polymers
The chalky surface is usually the first sign. Look at most of the plastic under the hood of your Jeep and you'll probably see similar signs. Good thing you caught it when you did, that was a fire waiting to happen.
You could leave plastic underwater indefinitely without harm other than just time.
Did you have hood vents?
Good info...
Yes I have hood vents over top of the injectors. I guessed the water ran down the injectors where the black and blue plastic meet. Once the rust started it expanded radially cracking the plastic. But if this can happen without vents, I can't explain it other than embrittlement from heat.
Old April 29th, 2018, 17:09
Black1990jeep Black1990jeep is offline
How about simply popping the hood when stopped when it is hot? add a spacer as needed, tennis ball maybe. just besure to secure before driving away! Maybe extend the safety catch length to allow it to still be effective with hood raised in front an inch or two, just incase you forget to close it all the way.
For slow offroading, pop the hood when driving, maybe add some hood pins to secure front of hood in slightlyraised position so it dont bounce when offroading. then remember to put hood closed for highway use? I assume a slighty open hood would reduce airflow thru radiator when on the highway, but would not be a problem for slow offroad driving.
Viable option or stupid idea?
Old April 30th, 2018, 08:53
Rockwood Rockwood is offline
I tried it, didn't seem to work well. I think the fans are helped a little by the proximity of the hood. The air leaving the fans would have to make a 180* turn to leave as well, and any heatsoak from the motor would have to cross the air curtain from the fans to leave.
Old May 1st, 2018, 07:24
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
The Latched hood acts as a sheer panel. Personally I would leave it latched off road.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old May 11th, 2018, 18:09
randy57 randy57 is offline
Hood vents are for dissipating heat to help with preventing heat soak, Not for engine cooling.
If people want to laugh that's on them, I'm sure the laughers do stupid things too that make others laugh at them behind their back.
Besides we don't get enough rain in AZ southern to matter.
Old May 13th, 2018, 16:33
But the same engineers who threw the D35 in the XJ designed the cooling system!
Old May 16th, 2018, 08:35
Bent's Avatar
And the hinge setup on the two door.
SoCal Chapter VP
Old May 16th, 2018, 16:13
sinat01's Avatar
sinat01 sinat01 is offline
and an aluminum steering box spacer
Old Yesterday, 18:37
Bruce L Bruce L is offline
I was lucky enough to find a rare set with gutters ,that came from a Grand Cherokee which had a 5.9 from the factory .no water what so ever and temp guage has went down a full 10 degrees .Here in the St Lou area we get hot and humid .My XJ is a 94 .4.0 .
Old Yesterday, 19:44
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
I put LeBaron vents on mine years ago. Never had any overheating issues, and still don't. When I sit at a red light and can see physically see the heat rising out through the vents, I know that it is doing something to dissipate the under hood heat.
I'm sure that the Jeep would have been fine without them. However, I like the way they look, they were an easy mod, they haven't had any negative affects to the way the Jeep performs, water intrusion hasn't been a concern. I'm happy with my decision.
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old Today, 08:33
Nice!
Still scouring junkyards for an acceptable solution before my Rubicon trip. While I don't anticipate cooling issues, I also don't like the idea of holding up a crew that isn't powered by heaters with crank output like my XJ (22RE 4Runner, 3 JKs) because of a failure.
Hood vent for sale Gravesdiggerxj InterMountain Chapter For Sale/Wanted 3 December 2nd, 2015 16:48
Anyone want my hood vent? 5.2poweredxj MWC For Sale/Wanted Forum 2 October 30th, 2007 18:50
Hood vent thoughts OKinNC Modified Tech Discussion 11 March 11th, 2005 21:02
