Old February 6th, 2018, 19:23
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Strange reverse light behavior
So I have been noticing that my reverse lights don't work when I first use the jeep. Once it's warm and I have been driving a bit they come on any time I put it in reverse. But the past couple months I noticed they don't come on after it's been sitting for hours. I also notice a burnt oily smell but I think that's because the power steering gear box leaks and the oil may be hitting something hot.
This is a 1998 Xj. 196k on the body and tranny. Did an engine swap in August 2016.
Old February 6th, 2018, 21:22
RCP Phx RCP Phx is offline
Re: Strange reverse light behavior
Clean the NSS !
Old February 6th, 2018, 22:48
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Yer as RCP Phx said it the neutral safety switch.
Here is a video on it, I have t watched it just the first video that looks right in a search
https://m.youtube.com/watch?v=70m0Pu6ZJ_0
These 4.0 like to leak oil, easily be valve cover, oil filter adapter or any number of seals starting to leak.
Old February 6th, 2018, 22:51
Well I canít edit the post in app to fix spelling. Trying to say yep RCP Phx is right, and you can replace it as well, but itís not hard repair it by cleaning the contacts. Further down the line it can lead to no start situations.
Old February 7th, 2018, 06:12
alexgalexg's Avatar
Thanks all of You!
Old May 14th, 2018, 19:50
alexgalexg's Avatar
Can the NSs cause a rough start? Today I started my xj and it started for like a sec and died. I started it again and it fired right up business as usual. Every once in a while it takes s minute to start after sitting overnight. Never any issues running and it's not always. Doesn't seem to be a fuel issue and since it's only on cold starts not seeming like CPS either
Old May 15th, 2018, 06:39
cruiser54's Avatar
cruiser54 cruiser54 is offline
Nah.
When's the last time you cleaned your throttle body and IAC?
Old May 15th, 2018, 07:06
alexgalexg's Avatar
Throttle body is done at least once per year as result of a heavy seafoam treatment (gas in ct has a ton of ethanol) but have not done the iac. That's a good place to start
Old May 15th, 2018, 07:07
alexgalexg's Avatar
Would you recommend cleaning or just replacing that part
Old May 15th, 2018, 08:07
cruiser54's Avatar
2 things. No fuel goes through the throttle body so seafoam in the tank is doing it no good.
Clean the throttle body and IAC. best to remove it. get a new gasket beforehand.
Old May 16th, 2018, 06:59
alexgalexg's Avatar
Well no I use seafoam through the throttle body. You let the engine idle and pour it in until half the bottle has been poured and then you let the engine sit off for 30 mins. Then you start it and go for a ride spending as much time at 2k revs. Cleans the intake, throttle body, piston heads and valves. But totally removing the throttle body is a good idea I will have to get a gasket
Old May 16th, 2018, 07:05
cruiser54's Avatar
It needs to be manually cleaned with an old toothbrush.
Old May 16th, 2018, 07:07
cruiser54's Avatar
And if you really want to remove carbon deposits in the combustion chamber and tops of pistons, do this. way cheaper.
https://www.cherokeeforum.com/f30/st...-4-0-a-226299/
Old May 19th, 2018, 22:33
alexgalexg's Avatar
Tops of cylinders still mostly sparkly gold. Did cylinder head swap in December and. The rebuild is on youtube as well. As for the iac it does run so much smoother after cleaning it. Also removing the entire throttle body tomorrow and cleaning it. However so far the late start is still not starting as nicely as it should. Likely unrelated to this thread but I'll update if I ever figure it out as a conclusion
Old May 20th, 2018, 08:46
trippled trippled is offline
I would put a fuel pressure gauge on it before you start it cold next time.it could be bleeding some pressure off or slow to build. Or you can verify it's not the fuel pump.
Looking for automatic trans reverse light color to wire in the reverse lights Atm3535 OEM Tech Discussion 0 January 19th, 2016 05:25
Steering gear strange behavior. Mar OEM Tech Discussion 3 August 4th, 2011 21:39
Very Strange Behavior DrSockMonkey NorthWest Chapter 3 March 1st, 2007 21:54
Strange air compressor/backup light/reverse problem rockethound OEM Tech Discussion 2 July 20th, 2005 09:54
Strange clank when braking, but only after reverse! Fergie OEM Tech Discussion 3 July 15th, 2004 23:00
