Old April 20th, 2006, 05:57
justright92xj's Avatar
justright92xj justright92xj is offline
replacing valve stem seals
i just got new valve stem seals from napa. they are victor reinz. the question i have is this. it came with six black seals, and six orange seals. seperate bags, separate part numbers. how in the world do i know which ones are intake and wich ones are exhast? other than the color, they look exactly the same.
Old April 20th, 2006, 06:06
langer1's Avatar
langer1 langer1 is offline
Re: replacing valve stem seals
Orange is generally High temperature so would be for the exhaust
Old April 20th, 2006, 08:25
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Other way round. Brown ones are for the intakes and the black ones for the exhausts. I used them on my stroker.
You'll need to remove the valve springs to install the new seals so make sure the valves don't fall into the cylinders, or else you'll have to remove the head to retrieve them. To avoid that, just make sure the piston is at TDC on the cylinder that you're working on.
Old April 20th, 2006, 08:50
RichP's Avatar
RichP RichP is offline
Remove rockers, then use air to presurize the cylinder thru the spark plug hole, it will keep the valves closed once the rockers are off. Most REAL parts stores should have the spark plug adapter as well as any of the tool trucks...
Old April 20th, 2006, 10:19
bajacalal bajacalal is offline
Either way, if you call Napa they should be able to look in the catalogue or computer and tell you which are for the intake and which are for the exhaust based on the part numbers.
Old April 20th, 2006, 16:07
SuperRA SuperRA is offline
I got some new valve stem seals and was confused for a bit until I took a good close look at them. One set had a veery small "IN" printed (molded) on them. The others had a very small "EX" molded on them. Unfortunately I didn't by the same brand so I can't help you with part numbers.
Leaking Tire valve stem bustednutz OEM Tech Discussion 1 December 11th, 2005 10:32
Valve Stem Poll FELIX Modified Tech Discussion 20 June 23rd, 2005 20:06
replacing d30 seals Kejtar OEM Tech Discussion 9 May 11th, 2005 06:31
Removing Valve Stem Oil Seals bzdel2441 OEM Tech Discussion 2 March 30th, 2005 15:10
valve stem tools GRNT Non-Tech / Off Topic 16 March 2nd, 2004 20:46
