Prev Previous Post   Next Post Next
Old November 21st, 2011, 05:35
joshthib@comcast.n's Avatar
joshthib@comcast.n joshthib@comcast.n is offline
92 Alternator Upgrade ?'s
92 XJ 4.0L HO AW4 182K miles
Recently the charging on my Xj has been sub par (or not at all the last two days) so I believe that it is time for a new alt. I have searched and have narrowed down my reasonable options to the 97-98 ZJ 130 amp and the durango 160 amp
I see that the alternators are nearly plug and play with the exception of grinding the brackets on the 2000-2001 Xj's and are able to fit without much more work on anything above a 98. I also have read that they will NOT work on the renix era.
My question is, what do i need with the exception of the alternator for my 92? will i need an external regulator or will my PCM handle it?
Thanks for the help
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 20:21
alternator upgrade mark91xjbeef Modified Tech Discussion 2 March 18th, 2011 06:31
90 Amp Alternator upgrade? montanaman Modified Tech Discussion 14 March 25th, 2007 10:08
alternator upgrade 160 amp ? low pressure Modified Tech Discussion 19 July 19th, 2006 07:37
Alternator upgrade Erik Litchy OEM Tech Discussion 3 June 15th, 2003 21:37
