Jeep is as ready as its gonna be. Still sometimes getting a p0171 running lean code but just gonna run it as is. Picking up the rental trailer on Wednesday
I started driving the jeep, found out the ball joints were toast. While replacing them i found i had a broken caliper guide pin and cracked caliper. I ended up buying 2 new calipers and pads along with 4 ball joints. $400 later my jeep is almost ready again
Well, that escalated a bit - turns out that part of my issue with the brake was the driver's side body bracket peeling away the body, like the passenger side did several years back. Fortunately a hunk of 1/8 plate, some bolts, and a uni-bit solved that, then it was just a matter of getting the drums properly adjusted, and now I have a solid parking brake again.
Just got to get packed, pick up a few things tomorrow morning, and I should be good to load up and roll out.
