redrider2911
- Yakima, WA
We were going wheeling and my friends jeep all of a sudden died and wouldnt starter, we popped the hood and noticed a melted wire off the main positive post of the starter relay. its green then turns to red after a boot. we traced it back to the steering column to the ignition switch where when turned on it crosses to a yellow wire. according to Chilton the yellow wire leads to the fuel pump and the alternator. When he turns it to "run" the fuel pump doesnt kick on and the radio doesnt work. when he tries to start it the starter does nothing, not even click. while the whole time the green/red wire and the yellow wire off the column heat up. We have tried bypassing the ignition switch, disconnecting the fuel pump at the tank, and disconnecting the alternator and the wires still heat up. The starter still cranks over if i cross the posts but there isnt any fuel in the fuel rail and most likely no spark since the acc isnt working. PLEASE SHARE ANY IDEAS. Thanks
