Changing rear xj 44 to a 5 on 5 1/2 bolt pattern brake question
89xjchick
I am changing the rear 44 on my XJ to a 5 on 5 1/2 bolt pattern. Does anyone know of a drum that has this bolt patten that will fit the stock D44 brakes, or do I need to change all the rear brake components.
Thanks!
Heather
Could you have the hole pattern redrilled on the existing drums (assuming you have some?)
It's done with axles often, too, but it's a lot easier - but not as easy as having the correct ones to throw on - sorry I don't know what they are, but someone will reply shortly.
Check out Jeepin.com. I believe Jason found a set that would work. CJ?
Later,
Lincoln
