Slightly diferent method for rear discs on D44 (tons of pics!)
all done.. only took about 6 1/2 hours or so... not too bad!
ZJ disc bracket and dust shield, inboard view:
donor axle shaft with new bearing, seal and TJ Rubicon retainer plate:
:( the bracket won't fit over the bearing! (but you already knew that ;) )
one of these will make short work of the problem
see? now they fit!
another angle
comparison between regular TJ backing plate and Rubicon backing plate (see how the Rubi plate has a little turndown to hold the seal in place? use the Rubi plate, then you don't need a custom-machined spacer):
on to the good stuff... raise the rear (use jackstands!) and remove the tires and brake drums:
pull the axle shafts:
disconnect the brake line, disassemble the drum brake hardware, disconnect the parking brake cable, and remove the backing plate (it should basically fall off!) Brake fluid will want to drain out, so I connected the new caliper to keep fluid from dribbling everywhere:
remove the bearing raceway:
comparison between theTJ/ZJ pattern and the XJ axle:
two holes need to be drilled and two need to be ovalled out a little:
growing pile of junk :D :
clamp the TJ retainer in place and mark where the new holes need to be drilled/enlarged:
done:
file off the burrs and clean up the flange so the new stuff fits flush:
bolt it up! everything fits...
install the axle shaft. i used a deadblow mallet to seat the new bearing. tighten the retaining bolts/nuts.
view of the new retainer plate/seal:
install the caliper. i didn't need to re-flare the brakelin; just re-routed it to fit a little better. i'll weld the tab to the axle tube in the near future.
not too shabby, huh?
for now, I have no parking brake. i'm going to remove the parking brake cables and install ZJ cables in their place instead of welding to the parking brake actuator arm to enable the use of XJ cables. (if you weld to the arm, you won't be able to remove the actuator anymore.)
Tomorrow I will do the proportioning valve mod to restore proper bias to the brakes.
The part number for the TJ Rubicon retainer plates is 1-05083678AA. You'll need 2, and they only cost about $4 a piece. Much cheaper than having anything made at a machine shop :D
Thanks to Stu Olson for his informative website www.stu-offroad.com and to William for loaning me his D44 axle shafts to minimize down-time.
Chuck
How did this mod work for you after all--------give us an update. I really want to do this now.-------Kyle
OK an update :D i tweaked one of the seals (my fault) and it leaked gear oil all over the driver's side. cleaned it all up, popped off the bearing, put on a new seal, pressed the bearing back on and buttoned it all back up.
NOW, I must say that I wonder why I didn't do this sooner! I have WJ front brakes, so with the stock drums I'd get a lot of dive unless I was really light on the brakes. now it stops nice and level and very controlled. Even without different front brakes, i'd say this is a worthwhile mod due to the fact that it'll give you much more controlled braking when you're backing down that loose hill you couldn't quite make it up... as good as they are, the stock rear drums just have no braking in reverse. i know they're not designed to... but discs are. i'd do this mod again in a heartbeat.
chuck
Nicely done. I think the word for that is "trick"
So it looks like those rotors have little mini drum brakes inside of them? I'm guessing those are the E brakes? I didn't know that's how they did that....
OK Im stumped!!!!!
Ive been looking at these photos and Stu's page also.MY model 20's used ball bearings but this uses tapered roller bearings.What holds the bearing in the housing???????
Yeah I know all that, but where/what applies pressure to the inner potion of the bearing.It seem all the rest just holds the outer race in place!
There's a big ass retaining ring. above the bearing in his pics you'll see about a 1/2" th steel ring that is TIGHT on the axle. It's actually much tighter than the bearing itself. That holds the bearing on. The race just rests against the lip in the axle tube and the seal and 4 bolt retaining flange is the preload on the bearing.
did you happen to buy those brakes off the boards?
i actually bought them (brackets & calipers) on JU. i'm not sure if they came off a ZJ D35 or an aluminum D44- but, as far as I know, either one will work. all other parts were new (parking brake shoes, pads, rotors, bearings, seals)
$125 used brackets, stone shields & calipers
$60 new rotors
$25 new pads
$15 new parking brake shoes
$50 new bearings & seals
est. ~$45 new parking brake cables (still need to buy)
$20 TJ retainer plates, fluid, odds & ends
So you're looking at about $340 total
Stoneattic--
I just did this change too, I am right down the road from you in West Bradford, Pa. If you want to check it out, hit me b-c. Pulled all of my hardware off a ZJ D44, but it can also come from a ZJ D35. I re-drilled the backing plate instead of the axle flange and had spacers made. Works just as well.
A.
Ive got everything to get started except this spacer or bearing retainer(s).How did you make them?Also what about E-brake cables,the newer Xj's are different!
I'm just finishing off this project. I had the brackets machined to fit my '87 D44 flanges and mounting plates. also clearanced to pass the axle assembly through. custom spacers are expensive! machine work was $325.00 CDN I love the way it "squats" down when you hammer the pedal instead of nose-diving now. I saw that most guys were welding a paw on the end of the e-brake lever to attach YJ cables or looping the end of the cable. didn't like the look of either plus it wont pass an inspection. working on a system using stock ZJ cables. re-locating the forward cable mount about 5-6 inches rearward. getting short intermediate cables made and connecting them with a brake cable union.
