iluv83vettes
- Houston
It's an NP 242 with the 10mm allen key plugs. I have soaked them in penetrating fluid for a few days, tapped on them with a hammer to try knock whatever is stuck loose in the threads and tried heating them up with a propane torch last night. I can't get them to budge. I can actually get the entire transfer case and transmission to turn (so a new transmission mount is also on the way).
I really don't want to strip it out and even with the nice fitting allen key, it is just turning the inside of the plug if I can get it to move. I already have the replacement plugs from NAPA (P/N 704-1048) to replace them with, so I don't need to be able to use them again, I just need to get them out without damaging the case.
