Old March 31st, 2021, 21:23
solomon7 solomon7 is offline
Way to power lights besides battery clamp bolt???
96 xj.
I added an h4 harness w relays and fuses for my headlights. Ram the leads straight off the battery clamp.
I then upgraded my cables, clamps and terminals and now the eyelets for the lights are too small for the clamp bolt and the clamp bolt is too short also.
For the time being, or maybe permanently, can i connect the power wiresfor the lights to the stud on the PDC that the battery and alternator run to?
It looks much cleaner and unless someone has a reason why I should not I want to keeo em there.
Thoughts?
Old April 1st, 2021, 06:42
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is online now
Re: Way to power lights besides battery clamp bolt???
What kind of terminals did you go with? I use military terminals so its easy to add stuff on As far as the eyelet, you could always snip off the existing one and replace it with a larger one.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old April 1st, 2021, 09:44
XJlimitedx99 XJlimitedx99 is offline
No reason that you can't connect there. Its electrically the same as the battery post.
Old April 1st, 2021, 10:16
Unclewolverine Unclewolverine is offline
There or back lug on the alt, it's all the same. I run an HD type battery with the top posts and HD type studs next to the post. Plenty of spots for my regular cables and all my accessories and extra grounds.
Optima 34/78 Bolt-in Battery Tray WebDog Vendor Advertisements 82 October 5th, 2018 06:47
Military Style Battery Clamp Question amsuco Modified Tech Discussion 18 September 20th, 2017 18:54
low power dimmed lights new battery HELP!! Shane_92-XJ OEM Tech Discussion 7 January 19th, 2011 12:29
rear stabilizer clamp bolt info EZridaz OEM Tech Discussion 0 March 25th, 2007 16:46
leaf spring bolt and spring clamp replacement? cjben Modified Tech Discussion 6 December 27th, 2006 13:06
