Old July 2nd, 2017, 10:20
BAXJ96 BAXJ96 is offline
Aw4 swap questions
Howdy all,
Tomorrow I will be swapping my warm out aw4. I have read the "everything you need to know about aw4" thread and it all makes sense accept for the wiring part. The thread says it's a simple cut and splice for a 97 trans into a 96 xj but the trans in my 96 has 8 wires in it and the one in the 97 has 5 wires. does that mean I only splice the wires that match? I know I may sound dumb but in need some help on this one. Everything else is ready to go accept the wiring
Old July 3rd, 2017, 17:30
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Re: Aw4 swap questions
Originally Posted by BAXJ96 View Post
Howdy all,
Tomorrow I will be swapping my worn out aw4. I have read the "everything you need to know about aw4" thread and it all makes sense except for the wiring part. The thread says it's a simple cut and splice for a 97 trans into a 96 xj but the trans in my 96 has 8 wires in it and the one in the 97 has 5 wires. does that mean I only splice the wires that match? I know I may sound dumb but in need some help on this one. Everything else is ready to go except the wiring
The TCU wiring connectors need to match, color wise. Some have a green connector, some have a tan connector and I think the later models have a red connector. I did the same thing with an 88 MJ using a 94 XJ AW4. I was trying to wire the 94 harness to fit the 88 truck. They had different wiring and I played hell trying to splice this to go with that. So the wiring harness need to coincide with the TCU. If you use the right harness, TCU combination everything should plug in, no splicing required. You may be able to source the right harness/TCU at a salvage yard or ebay
LS1 Swap Questions /ZexGX Modified Tech Discussion 7 March 31st, 2011 11:18
2.5 I4 -> 2.8 V6 swap questions sureshot007 Modified Tech Discussion 26 October 5th, 2010 20:39
8.8 swap questions alex22 Modified Tech Discussion 23 April 8th, 2008 21:54
2.8 to 4.0 swap questions? geepxj OEM Tech Discussion 7 May 22nd, 2006 19:05
350 swap questions K2fender Modified Tech Discussion 14 November 15th, 2005 23:57
