Old June 30th, 2020, 14:10
uglyrenixxj uglyrenixxj is offline
TV cable adjustment (w a twist?)
So,
Digging into a topic that has been somewhat covered, im looking for a sanity check.....
This thread (post 116, and 117 specifically) pretty much sums up my situation.------> https://www.naxja.org/forum/showthre...1015963&page=8
in short, they contradict eachother. 1 says release cable button AFTER pushing in the "conduit", and the other says to release the AFTER WOT.
I have the factory manual, and have included a video of it for clarity https://www.youtube.com/watch?v=GiCCX3x9uVU
Seems pretty straight forward right?
LOADS of videos saying to do it 1 way, and factory manual saying to do it another way.
took me the better part of 2 months to rebuild the trans, and dont want to go thru that again. Just looking to get the adjustment right.
Anyone have any advice based on experience?
Old June 30th, 2020, 22:56
lawsoncl lawsoncl is offline
Re: TV cable adjustment (w a twist?)
I've done it both ways but prefer the method in the FSM. If you don't hold the release button down when fully opening the throttle, it'll still pull the adjuster back out to the right position. It's just takes a more force.
Old July 1st, 2020, 12:40
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is online now
X2 on holding until it's w.o.t. it was the Only way I could get mine accurately adjusted.
AW4 shift (NOT TV!!) cable adjustment HappyDog OEM Tech Discussion 4 January 18th, 2014 06:32
AW4 Shift cable adjustment gcurtis OEM Tech Discussion 2 January 6th, 2009 12:33
throttle cable adjustment? rufus_1111 OEM Tech Discussion 1 July 22nd, 2008 21:47
AW4 TV Cable Adjustment Q CantonXJ OEM Tech Discussion 1 May 23rd, 2006 19:03
Shifter Cable Adjustment???? eric91xj OEM Tech Discussion 2 May 5th, 2003 18:01
